Jammin'Trey
- 74
- Jun 11, 2009
Omaha,
Nebraska
Here is a log of a 3rd gear pull I just did, trying to get knock suppressed with the methanol injection. I am tuning for a 11.3-11.5 AFR. Meth is a 50/50 mix with water. 7gph nozzle, not sure on the psi, (SMC subaru methanol kit...). Here is a little about the car, 2.5in 02 housing, 3in dp, 3in catless exhaust, PTE 1000cc injectors, fuel lab 515 reg set at 43psi idle no vac, Walbro 255lph, 4in core FMIC with 2.5in hardpiping, 14b turbo, Hallman MBC set at 18psi, creeps to 20 at 5-6k (doesn't bother me at all). Stock cams, 91octane fuel, DSMlink is set for base timing, I have no timing added in. (Innovate LC-1 Wideband is logged....)
Meth is injected about 3in from TB.
I have had to take out a S*** ton of fuel for the meth to get afrs around 11.1:1.
Meth starts spraying at 10psi, I beleive pump goes full at 15psi...
