phill
- 144
- Aug 20, 2007
Chandler,
Arizona
I recently moved from Pheonix AZ up to Flagstaff and I've noticed a deffinate change in power. so I started searching on here about what altitude can do to a turbocharged car. I read that you'll use 15% power or so and that you can raise the boost to compensate. I was wondering if I can raise the PSI on my car to compensate or if I should just deal with it? I'm running 7 psi now on a stock block with a FMU.
