420A What's the best way to tap oil pan?
Uh take a drill and drill a hole into your pan about the size of your bung?? Not really hard..
Borrow a welder or take it to a shop. Its not too difficult dropping the oil pan. Use a center punch since that was not given yet.
1. Drain Oil.
2. Remove oil-pan.
3. Drill appropriately sized hole, preferably above oil level line and on front of pan.
4. Thoroughly clean oil-pan.
5. Do one of the following:
a. Weld in return bung.(recommended)
b. Install bulkhead fitting.
7. Reinstall oil-pan with new gasket.
8. Fill with your favourite motor oil.
9. Plumb oil return line.
10. Enjoy.
