View Single Post
Old 07-03-2009, 10:33 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #1 (permalink)
oplix Offline
Proven Member
oplix's Avatar
Tech Posts: 191
Classifieds Rating: 0
Reputation: oplix is an unknown
Slipping in all gears
I'm having a drivetrain issue and I'm not 100% sure where it's coming from. My drivetrain is slipping in all gears but there is less slip the higher the gear. 1st and 2nd gear are the worst. I can't build any boost at all in those gears. Fifth gear is really the only gear I can build any boost in and hold it without slip.
I recently replaced my master and slave cylinder and also got a stainless steel clutch line. It was running good for a bit but then I started getting deceleration chatter but now it's slipping like hell. The deceleration chatter went away though.
I haven't taken a look at it myself but would like some opinions on what to look for. Like I said I'm not 100% it's the clutch itself and it could be a tcase issue.
Last thing is that for example when i floor it and it starts to slip, both the rpm AND speedometer gauge will spike. I've had my clutch slip a little previously but never remember that the speedometer spiked, only the rpm gauge.
____________________________
Ilya B. - AWD Inside.
Advertisement
To browse the forums without the advertisements above, Login/Register
