Whoops, missed the A/R .48 note after the turbo.
Well, we can't tell you what to expect hp wise from the system as that's bench racing and is against forum rules.
You should easily get 20-23 psi, but I'm not sure if that's in the turbo's efficiency range.
Again, what do you have for a logger/tuner, as you won't be able to run those injectors without something to control them.
Do you have a boost controller?
____________________________
Brian
