I just used duplicolor engine enamel for my valve cover. ( i believe thats what its called)
but any paint that can handle some heat should work.
There are probably around 8 10 mm bolts around the valve cover, its pretty easy.
and the blow off valve is just the plastic piece of shit that should be recirculated to your intake...
it should be pretty easy to find if you know what to look for.
____________________________
-Parker
