Quote:
Originally Posted by PieEyedPiper
Is a pocketlogger cable at all compatible with this? I did see you recommend the open port 1.3
BTW, very ambitious of you to make something like this. I hope that you get a good following from us 2g guys.
EDIT : just played around with it, I like it so far!
Don't think the PocketLogger cable will work.
The MUT protocol uses 15625 baud, which is a odd ball speed.
Pocketlogger uses OBD2 which is 10400 baud.
Any cable that uses the FTDI chip should work, like the OpenPort 1.3.
OpenPort 2.0 won't work.
I've seen some cheap cables on ebay for VAG cars, I might order one and see if it works.
VAG use K-Line like us.
Thanks.
