dbednarsky
- Sep 18, 2008
Stratford,
Connecticut
I have a unique issue here and I will try to provide all info.
1996 Dodge Avenger 420a N/T Motor (now it's turbo'd)
Had it tuned at a local shop, and they did an ok job, except for 1 BIG issue that they insist it's not the tune, but I am certain it is.
390cc injectors, 4psi of boost, walbro 255lph pump, aeromotive fpr, 6-an Lines for fuel feed, and 10-an return,
Apexi AFC Neo controller w/ factory ecu
car runs great under normal driving, runs great while in boost, but when I come out of boost it starts to sputter a bit, and then stalls, when I pull it off to the side of the road, it won't start and I could smell the fuel, I know it is flooding out. seems like a carborated lawn mower that has been over primed. After letting it sit for awhile it will start back up and run like a bag of crap for a bit, but will eventually run fine again after a few minutes. it is like the car is not backing off on the fuel delivery when I come out of boost. Any help or can anyone tell me what to look for in the program.
If you need any info from the NEO let me know and I will get it. any help is going to be greatly appreciated.
I want to go to the AEM F/ic but i just can't afford it now, and with the nice weather approaching I would love to be able to drive the car
Thanks again in advance
