Removing baffle from valve cover?
After drilling my valve cover for an 8 and 6 AN set of fittings, is was working on cleaning it out when i remembered a guy who had all the little tabs holding his valve cover baffle in break off and ruin his motor.
Has anyone just straight pulled it from square one when doing a large PCV/breather system?
I would like to take it out for piece of mined and leave it out. But honestly with the drilling and what not that was done for the AN fittings, I will be removing it to clean under it either way.
Then is just becomes a matter of welding tabs back on to hold it, or leave it out.
Anyone with any intelegent input on this from experience? Or anyone know the exact purpose Mitsubishi installed it for?
Reason: Trying to make you look more intelegent.
