2G Transmission / tranny bolt size, length, pitch, location, part number and pictures
This applies to both AWD & FWD, M/T & A/T (97+ A/T uses MF140271 for the "U" bolt). Thread pitch are all 1.25mm.
  • V (MF140471) : M10 x 65mm
  • U (MF140266) x 2 : M10 x 40mm
  • Y (MD740892) : M10 x 43.5mm
  • Q (MD706012) : M8 x 60mm
  • The Q bolt (red arrow) is the only bolt that goes in from the block side and threads into the transmission.
  • There should be hollow dowel pins(MD020260) at V Q where the bolt goes through to align the block and transmission.
  • The U bolt above V is not used when you swap a 6bolt block to your 2G tranny.
*Thanks to @802 Garage for noticing the error in the U bolt part number. Correct number now shown.
