kittay
- 696
- 2
- Dec 20, 2007
Boise,
Idaho
On ebay, there are adapter for a 2g to Evo MAS.
If it were possible, you'd have to buy a 3" filter adapter and screw it to the "inlet" side of the sensor, being sure that it is PERFECTLY sealed to prevent a possible boost leak.can the evo mas be used in blow through?
why do you say it out flows the evo mas?
The #482 MAS actually makes a very nice upgrade, as it appears to outflow a 2G MAS, and it is the same 3 1/8" round diameter as a 1G MAS, making the swap very easy.
I have a 3G maf and have removed the black plastic 'shroud' entirely from in front of the honeycomb. All I needed to do was apply silicone to the edges of the honeycomb to get it to stay on the MAF. It probably outflows the EVO maf some.
This is sad for FIPK owners.
Anthony, have you done any testing yet?
PieEyedPiper said:Also, I've read that the 3g mas is identical. I've not seen one in person though, but I can already imagine that it, too, is of round shape and not the 2g oval.
All of a sudden that K&N investment wasn't such a great idea.
What kind of testing do you mean? I did just post up this info, if that helps.
You do realize Justin posted up pix of the Evo 8 and 3G MASs in this very thread, right?
As far as using the FIPK kit, I always remember this post from Jim (FORMONTOYA).
PieEyedPiper said:Anyways, thanks for the info and reminding me to clean my eyeballs
