2G Hard cold start problems, cooling fan always on
brandonzero0
376
2
Sep 1, 2005
Detroit, Michigan
My car has a bad starting problem, it will start shut off start shut off and keep going but when it warms up a little bit its fine but when its idling/running the cooling fan is constantly on I searched and didin't see a problem like mine, I am assuming its my coolant temp sensor, any other ideas any one?
look up (no start) i had this problem before . do's the car start right up after its bin running for a while? if so that is most likely the prob. if so its only about 25$ to fix. do you have a heavy gas smell when trying to start? or a big ploom of black smoke out the back when it start's?. also my (cel) was tripped from this problem. is yours?:talon:
no gas smell no cel thats another problem of its own as well and yes it starts fine after its been running for a while.
sounds like the sensor. i would try the bone yard first and get the sensor there. not sure if the were diff from the years but its worth a shot. or if you get it from autozone and the problem still there you could always just get a refund from them. my gsx would crank till it was just about dead battery then fire up and look like an old john deer tractor.(alot of smoke) but once it was at running temp it would fire right up.
It's the temp sensor or the wiring harness for it.
My friend with a 95 gst had the same problem. Hard cold start problems, fans are constantly on and no CEL.
We found the harness for the sensor is broken.
Did you figure out what the issue was? I am having similar problems and my temp sensor is fine
you DId check the correct sensor right? there are two, the 2 wire sensor is the one in question. just asking ### ive seen this mistake many times
Could you expand on this. Ive been watching this thread and searching others because im having the same problem. I found a diagram posted for these sensors for a 1 g but i cant find where they all are and what they do on a 2g.
Im pretty sure ive already replaced the wrong one (cause i broke it pulling off a connector before) I want to make sure i get the right one without having to buy all three
