Quote:
Originally Posted by Burnett03
There are so many features on link that help the 1/4 mile time, the biggest being NLTS and studderbox. I still think you will make more power with link than what you think. You can control the timing at wot and spool up to help spool the 16g even faster. You can't do that with an afc. You can also change the a/f ratio on spool up to get it to spool faster. Also something the afc can't do very easily. Plus now you can post on the link forums, and the knowledge base is much wider on there. If you do decide you want nitrous link can control it, or can also control water meth injection. Get the link, get a wideband and a map sensor and you will be making more power i promise.
Like I said!
Good choice in getting link. You wont regret...
If your still left wanting more in the future and cant go nitrous then maybe you should consider a turbo upgrade, like a cheap 50trim setup or something.
