Thanks freereving for following my post so closely, it definitely helped. I wasn´t sure how to use the feeler gauges, and when i did it the first time i did it wrong, and surfaces where not clean, thats why the bad numbers. I can now pull out a .002 feeler gauge out of the middle of the block. Now, im not convinced if the block is warped or not since im using a level and im not sure if its straight enough. So ill send the head first, see what happens with it, and go from there. Thanks, for the help.
