Are you sure that the throttle cable isn't too tight? The higher idle when the motor is warm can cause that. Check the link I gave in post #9, there is some good info there.
Have you resistance tested the ISC coils?
Do you have a logger to check throttle position (compare cold vs. warm engine) and coolant temps?
____________________________
Romeen
