I don't know if the neutral switch would cause your exact problem. When you say you crank it and it acts like the clutch pedal isn't pressed do you mean you try to start the car and it lurches forward? I'm not sure what happens if you have the neutral switch unplugged and you try starting the car with the clutch pressed in...
Everyone is saying unplugging the switch might work, sure, but you'd be basically ignoring the fact that it isn't starting up like it's supposed to.
