Quote:
Originally Posted by Car Cannibal
Did you run the stock 3 bolt rear axles when they sheared off at 30psi??
I sheared 3 bolts as low as 20 psi with drag radials, the 4 bolts give up a little past 23-24 psi. Most of the time it is the driver's side shaft.
