lq1driver
- 206
- Dec 17, 2007
painesville,
Ohio
Hello guys i want to see what you think
I took my car to the track a couple weeks ago. and ran a best of 14.5 at 99.8. my total build up goal is for a 13.5 car. my mods are ssac fmic, 14b with minor porting, 3" cat back with a test pipe, high flow intake, rewired fuel pump, and this was on 15lbs of boost with a minor boost leak and 245/40/18's so not the best for traction. do you think that 21lbs with 550cc injectors, 1g throttle body, a megan racing down pipe, and blow through should take me close to what i want if not what i want. i know that for big power numbers go with a 16g and dsm link but i want a 14b build up just to see what can be pushed out of this little thing. Now also im thinking that when e85 becomes available up here i will make the switch to lower knock what do you guys think?
