View Single Post
Old 06-23-2008, 07:14 PM   #1 (permalink)
turboglenn
Proven Member
turboglenn's Avatar
Region: Midwest
Classifieds Rating: (2)
Reputation: turboglenn is extremely helpful and trustworthyturboglenn is extremely helpful and trustworthy
Tuned the car @ 30psi on E85 today
Well, just as it says, i got the 30psi range about dialed in. On the last pull i saw as lean as 12.0:1 at about 7k in 3rd gear. everywhere else is 11:1 just about dead on. I'm not sure of the pulse-width i have left up there at that RPM as it's still pretty high even with the new 255 HP, but I'm only running 36psi fuel pressure so I'm hoping a bump back up to 43 will help out a bit since the new pump is the high pressure model. Anyone know how much better it hold flow in higher pressure situations?
One thing i do have to say is WOW! The car is a monster at 30psi. I got the surging issue taken care of (checked and re-adjusted everything in the intake track that i can unbolt, not sure what it was) One thing that's had me impressed is that i haven't blown a dipstick or any oil out of the cap at these pressures either 8)
If the higher fuel pressure doesn't allow me to keep pulse down I'm definitely getting a dual pump setup since i know I'm not making over 500hp and the 1000cc injectors should be able to do that on e85 at less than 100% IDC all day long from the math I've seen on peoples posts.
I'm seeing intake temps of high 130's to low 140's by the end of a 3rd gear pull, and after a 2-3-and part of 4th i saw 157*. This is without methanol for cooling and the car hasn't shown one bit of knock at these pressures and AFR's
I"m thinking about adding either pure meth or pure water back in front of the turbo for added cooling and to broaden the compressor map up some at these PR's
Just had to post since my car's only really ever been dyno'd at these boost levels (28 actually) and not driven on anything over 24-25'ish, So I'm pretty stoked.... It's definitely getting too scary for the streets when there's traffic.
Offline
Related Auctions
Sponsored Links
