NewTurboTuner
- 535
- 22
- Jul 21, 2006
Rslv,
Arkansas
Something is going on with my fuel pump, or fuel pump relay? ....I don't know? Maybe ECU?
When I turn my key to the ON position, my fuel pump does not turn on to prime the motor.
BUT when I try to start the car, the pump turns on for the initial start-up, but then turns off after about 5-10 seconds.... then the car dies from lack of fuel. I can try to start the car over and over, and the pump still only turns on for the initial start-up, then turns off. I can hear a click or switch when it switches on/off. The click is coming from somewhere near the driver side dash.
Has anyone had this happen before?
I didnt have time to look the car over last night. I pulled the battery, checked the relay, and my ground wires but everything looked good. I plugged it all back together and nothing changed ....still the same thing. I did not check any fuses yet.... I didnt have time.
I'll look everything over later today. It'd be nice if someone could give me a hint, or something
