dsm link ordering
obee1595
45
Jan 2, 2005
peru, Illinois
im ordering my dsm link and be4 i do it ask for my injector sizes my my rpm, launch maft and rev meter and ideling so if i select stock for all them does it matter becuz i plan on putting bigger injectors in? and im ordering from extreampsi.
thanks :talon:
Wow, that sentence sucked.
.. You can change whatever you need to in link. All you need is the right generation for your year of car, and a socketed eprom ecu.
The settings you order with will become your default settings should the ECU ever lose power, i.e. battery disconnect. Just say what size injectors you plan on running stock, what you want your default launch RPM to be, etc. You can change anything once you have it installed.
PS, using programs like Firefox or any other browser with spell check makes reading posts that much easier.
thanks :talon:
I'm ordering my DSMLink, but before I do it, it asks for my injector sizes, my launch rpm, and stock idle. If I select stock for them, does it matter if I plan to put larger injectors in at a later time? I'm ordering from ExtremePSI.
FIXED.
Just select the stock sizes for now. You can change them later. If your ECU loses power, the settings will revert to the settings you select now.
FIXED.
I was thinking of doing that, but you beat me to it :)
  • For sale 1g 90 Oil Cooler
    • kyler021
