Clutch dose'nt want to disinguage after car running for awhile
l3igl3ang
539
2
Aug 10, 2005
ft smith, Arkansas
Yeah i can drive my car around for awhile then the clutch starts to slip and dose not want to disenguage. I can feel it in the pedal when it starts doing this the odd thing is it dose'nt do it till after i drive it awaile so dose this mean i need a new clutch master or do i have the pedal adjusted to far in cause i had to adjust the screw under the dash to get it to go in to gear when i installed the stage 2 clutch.
No it gets where when i let off the pedal the prussure plate wont relases all the way causeing the clutch to rub and stay somewhat enganuged. its like driveing and barley holding the brakes and its burns them up.
That means its not fully engaging. If it wont disengage, that means the clutch doesnt release when pressing the clutch pedal. You have engage and disengage confused.
Anyway, check for pedal pump up.
ok will do i will back out the adjustment under the dash and see if that fixs the problem
