View Single Post
Old 05-15-2008, 07:59 PM   #32 (permalink)
1992awdlaser
DSM Wiseman
1992awdlaser's Avatar
Region: Tri State
Classifieds Rating: (0)
I took another look at your logs and saw that the knock is a constant 3.2 degrees. This means either your knock sensor is unplugged or there is a short or disconnection in the knock sensor wire. When there is no signal from the knock sensor to the ecu 3.2 is the default setting.
So put your timing back at 0 and find the problem.
Online
[posts] [blogs] Reply With Quote
Sponsored Links
