View Single Post
Old 05-12-2008, 09:00 AM   #12 (permalink)
Allamricn
New Member/Lurker
Allamricn's Avatar
Region: Midwest
Classifieds Rating: (0)
Reputation: Allamricn is an unknown
Quote:
Originally Posted by Just4Fun View Post
I just did this install two days ago. Got the pipes used off eBay for a discount. Put in the Dejon LICP and UICP piece from the SMIC outlet through the BOV flange. I also have the HKS SSQV. I don't have the piece going from the BOV to the throttle body yet and am debeting whether to get it.
The install was a lot longer than I anticipated. All of the plastic clip/screw things are a pain, but the hardest problem I had was getting the stock UICP off. There are two bolts under the relay that connect it to the body and there are lines running right over the bolts so getting to them is quite difficult. Needless to it takes a lot of patients and I'd suggest getting a racheting wrench for those bolts. Putting the hard pipes on was much easier than taking the stock pieces off. Since you have the HKS BOV you know how much fun dealing with the C-clip is.
I do now have a boost leak somewhere and haven't built a tester yet to find and fix it, so I can't say how much of an improvment I've noticed yet, but hopefully in the next few days I can get it all ship shape.
Great, wonderful news I was hoping it wouldn't be a pain, but it sounds like the pain was more getting the old off instead of the new on. Let me know what you find out about your leak as I would like to avoid any if possible. Also, did you put your HKS on the piping prior to installing the pipe or did you have the pipe in place first. Also, with the new UICP, were you still using the stock recirculation hose?
Offline
