Quote:
Originally Posted by bullettdsm
Lol@ da Peepers.
Did you notice my man Hoff did that without a seatbelt? Impressive
MB
Just some info to help educate. I see a lot of 420a guys ask what injectors someone is running and then start talking about fuel cut. Fuel cut is not a fuel thing it's a air thing. The engine in stock form or I shoudl say ECU and sensors in staock form have a air clamp. Meaning when it senses a certain amount of air or pressure it cuts fuel. Fuel cut is not a matter of not having enough fuel. If that were the case the car would just run lean and knock. I know you think yoru spring is your problem but it's not. Your manual boost controller even thought it's a cheapy is good enough to raise your boost double that of yoru spring in your wastegate. So unless you have like a 3psi spring your have another problem and like everyone said I'm betting on FCD or missing like so let us know when you get one what happens.
