Hurst Pro-Matic 2 ratchet shifter installed in my 2g
mini zilo
783
18
Jul 17, 2006
Chicago, Illinois
I got my hurst pro-matic 2 ratchet shifter installed tonight in my gsx. I bought it at Advance Auto parts for like 170 bucks. Every once in a while I do things that dont make sense LOL.
Anyways, it fits very well with my center console and everything. The cable went in very well and I had to mess with the trans bracket a little but I got it to work. All I had to do to install it was remove the old shifter obviously, and then drill new mounting holes in the floor. Then I used some washers to get the shifter nice and level, and then secured it down with sheet metal screws.
The ratchet shifter will be very good to use along with the RMT shift box that I have installed in my car (quick manual shifts at full pressure). I am making a plate out of some sheet metal to cover up the big hole in the console, and I am going to mount my overdrive toggle switch on there.
Is anyone interested in a write-up of how to install this shifter? It is fairly easy, and takes about 2-3 hours total to put in. It definitely gives a better "feel" then the stock selector.
Here is a few pics and a vid of how the ratchet action works:
You LIFT the shifter from park to go into reverse, then pull back to neutral, then push DOWN to ratchet into drive, then ratchet back to 2nd, first, etc.
<object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/P7SLdFmsx90&hl=en"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/P7SLdFmsx90&hl=en" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>
Let me know if you guys want a write up or something, and let me know what you think overall!
will that work for a 1g? why the shift "knob" and not the hurst T handle?
I would definatly like to see a write up on that install.
There have been a few members asking about installing a rachet shifter, I'm shure they would like it aswell. :thumb:
I'd like a write up. And the part number for the shifter, from summit racing or hurst doesn't matter
Have you thought about using a manual shifter boot, instead of making a plate?
Yeah, I actually tried that first. The problem is, the shifter wont ratchet to lower gears with the boot because it hits into the little plastic trim piece that holds the boot. I tried trimming that too, but it just looks bad.
Alright guys, it is fully installed/tested. It works great! I will get some driving videos up very soon. I also made a little plate out of sheet metal to cover the gap in the center console. I painted it flat black to match the interior.
The install was fairly easy, I just had to drill some holes in the floor and use sheet metal screws to mount it, using washers to keep it level. Then I ran the cable through the firewall in the stock hole, and then used a vice and a really big wrench to bend the stock manual control lever on the transmission ( the thing the cable attaches too). From there, I used one of the brackets that came in the kit to hold the cable, and then got some lock nuts and washers to hold the cable to the manual control lever. Here is the finished product, let me know what you think!
I decided that plate looked a little too out of place, so I did some more cutting (cutting that I originally did not want to have to do) but I got it to work with the manual boot. I also put a T-handle on because the shifter is much easier to "operate" that way.
nice work, now for some driving videos!
Here is a video of me using it.
I don't manually shift it like this just normally driving, I just leave it in D, but I did it in the video so you guys can get an idea of how the shifter works.
<object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/ZlRCKARtfCo&hl=en"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/ZlRCKARtfCo&hl=en" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>
Where can i get this one from?^
I guess I need to get or make a shift box first... But please do a write up, that'll help take some of the guesswork out for the rest of us.
  • For sale 420A 420a block & EGR/ FUEL RAIL INJECTORS
    90PSI compression test. Possible damaged piston rings, unsure. Possibly good for a...
    • Stizzydrew
  • For sale 420A OEM 420a throttle body
    $40 + shipping + fees (PayPal) Pick up CA 91605
    • Stizzydrew
  • For sale 420A 420a intake manifold
    $80 OBO + shipping + fees. (PayPal) Pick up CA 91605
    • Stizzydrew
  • For sale 420A 420a thermostat housing
    Oem thermostat housing 420a $20 + shipping + fees.
    • Stizzydrew
  • For sale 420A NVG T350
    New venture gear T350 M/T 420a
    • Stizzydrew
