turboglenn
- 6,375
- 123
- Nov 5, 2007
RIpley,
West Virginia
Does anyone know how to configure other ECU's for the 420's triggers? It's weird having 2 sets of 3 teeth 180* out from each other on the crank, and then the CAM angle sensor has 3 magnets (triggers) So I've been confused on this one.
I can't tell if it should be a multi-tooth and where or when the "missing teeth" would occur, I have no clue what corresponds to what as most have triggers that are evenly divisible by the amount of cylinders. But, I haven't studied the motor in depth either. I've just been wanting to get a wire harness built for the Haltech to run on My girl's Neon (turbo SOHC). My plan is to have a wire harness built for what ever ECU We actually purchase for it, but I will probably set it up for a Haltech since I know the system so well.
Anyone contact me if you have knowledge of the triggers and what edge they trigger on.
j/k
