View Single Post
Old 03-04-2008, 10:33 PM   #8 (permalink)
absolute_DSM
Proven Member
absolute_DSM's Avatar
Region: Rocky Mountain
Classifieds Rating: (5)
Reputation: absolute_DSM is pretty helpful and trustworthy
Quote:
Originally Posted by 92awddsm View Post
Another advantage to using npt as opposed to metric or sae straight threads is oreintation of angled fittings when tight. With o-rings or crush washers, once it is tight, it is tight. If it is a 90* fitting and pointed 180* opposite of what it needs to be, the only remedy is to start indexing (stacking crush washers or o-rings until it points to where it needs to) which is prone to leak. With npt fittings, once tight, you should have at least120* of adjustment tighter to get the optimal oreintation of the fitting.
Well put. It may cost more, but I use straight AN adapters, then 90* swivels.
Ill learn how to save money eventually.
____________________________
Eric
Offline
[posts] Reply With Quote
Sponsored Links
