Thanks Alot for your help!!! New update the new pcv valve I had was garage I put back an old Mitsubishi one now it sucks air in the intake instead of letting the pressure from the intake go to the crankcase. Ps Stay away from Autozone Pcv Valves!
Also changed the intake manifold gasket set the motor to 30 Degree ATDC. Did the boost leak test again and got a steady 20psi. So that should eliminate bent valves and maybe timing being off? I did find small leaks at 2 injector seals and small leak at the tps sensor. Im going to jus install my new 650cc since they have new seals and im gonna need them for my 50trim neway.
I would say the reason why the blow off valve wasnt makin any noise because the intake manifold pressure wasnt full enough because the pcv vavle was letting the air from the intake go into the valve cover and plus the intake manifold gasket leak. i will let you guys know what happens when I put everything back together.
