Quote:
Originally Posted by marioortiz69
Try to stick a pen magnet in each cylinder and see if you pull anything up. I had my valves break off and my car ran for 2 months with only 14 valves. It ran fine! Probably not good for the rest of the engine but it worked.
I stuck a magnet in each cylinder nothin came out altough my spark plus look pretty black and their brand new
Quote:
Originally Posted by mach4g63t
If you have aftermarket gauges, the oil will remain low unless the engine is being revved or moving under load, because the pump is not being spun. As for the lowered, vacuum, this is generally a result of the engine getting more air outside of the turbo, ie a boost leak. The ECU frying would have nothing to do with what conditions you are describing. Unless you have some sort of electric boost gauge, a mechanical boost gauge takes all it's readings directly from the source of vacuum attached at the base and monitors boost and vacuum mechanically.
I dont have an aftermarket gauge im using the stock gauge but neway I rather fix the boost problem because I could always buy a new oil pump if thats the case.
Quote:
Originally Posted by Epic904
So it all happened after the turbo install. Basically 10 in/hg means your idle has to be real pour in either a boost leak or even not firing on all cylenders. The oil pressure problem could be something as simple as a bad sending unit, a bad ground, but where do the new turbo draw it's oil from? If you did ground out the postive cable i would check some of the fuses under the hood before pulling out the ecu. The vacuum leak could be the throttle seals as these are 18 year old cars. Also check to make sure the vacuum line to the gauge is good and not leaking. As for the coolant temp. guage going crazy what do you mean by that?
Im drawing oil from the oil filter housing. The coolant temp gauge was reading normal than when I reved the engine was flickin up and down fast and the oil gauge was going up and down too. That problem could also wait just thought I should mention it just incase it has anythin to do with what's goin on.
