I had two goals when I opened my tranny. To replace the worn out disc and find out what pp I had since rre didn't list one in the build. They also didn't list the clutch fork and pivot ball as being replaced so I'm going to replace those along with the oem pp. Gonna go with a 2600. Going to replaced the act flywheel too. The guys at RRE said that should fix my problem.
Quote:
So you were originally running the "no name" PP? and just changed out the OEM disc for an ACT?.
Correct.
I replaced the throw out bearing too. I'll try adjusting the master rod tonight.
