Quote:
Originally Posted by dsmsucks
I was having the same problem as you. I would bleed and adjust the master cylinder, NOTHING. Well turns out I had a nt slave cylinder(shorter rod). Changed that, and it fixed the problem
good luck
They are the same length. However, the bore is different. That is why it worked. I could put a 1/4 shorter rod in and it would still work the same.
