I have the exact same problem as you except I just installed an act 2600. I put my car in reverse and pushed in the clutch and tried to start it and now my car is stuck in reverse and wont start because it keeps jumping. I have yet to play around with it so I have not fixed it yet but when you find out what your problem is please post it on here with what you did so I can try something else. I'm about to adjust the clutch pedal to see if that helps, I bled the system entirely and m/c and s/c are both in good working order.
