- Thread starter
- #26
Killa_dsm
- 2,161
- 22
- Aug 31, 2004
Bay Area,
California
It looks like you're on the right track to be getting your timing back that well from only a few % in a few areas! What are you running now for meth mixture? I was running blue juice (which i found out today that what i had been running was only 30% meth 70% water) I dumped 2 bottle of heat into the 2qt tank when there was only a 1/4th of a tank of blue juice in there and as soon as the higher meth mix worked it's way through my knock went completely away.
41lbs/min looks rather nice too, that's a good bit of air!
I was running blue smirf piss, I think the 50/50 mix and the color dye. But I decided to run straight meth to see how it would affect my tune. So I put in 3 bottles HEET and thats the log you see.
41lbs/min is not significant, unless your 2g head is stock and stock intake/throttle body. Meth injection is like racegas. Turn the boost up. 23psi on a fifty trim is low for a pump/meth tune.
Yeah, I plan to run more boost but I wanted to get my timing back up to where it was suppose to be. And yes I have stock head/intake mani and throttle body. So how many lbs a min should I be seeing? I hope to get it tuned to about 24~25psi on pump gas and meth. We will see how that works out.
