Quote:
Originally Posted by Defiant
A clutch throwout isn't withstanding anywhere near the pressure a brake system is: you'll not be able to expand a reinforced line with it.
well I already agreed it's probably the clutch rod like you said, but wanna bet about that pressure statement? It's not normally at brake pressure, but the MC bore size is the same and your foots the same, so you CAN apply near the same pressure...
