Boostdclips99
- 306
- Mar 19, 2006
Roanoke,
Virginia
Im having issues with my tps at the worst possible times. I have DSMlink but for some reason it will not connect. I resorted to using a voltmeter to set the tps ohms to .63 on pin 4 and 2. I have it set but when I take it for a drive the injectors are not closing, causing it to stay rich when letting off the throttle in gear. Usually the wideband reads completely lean but instead it is reading 10-13. Checking the ohms on pin 4 and 3 it reads .03 so there is still continuity. Do I need to adjust for 0 continuity or .63 ohms? I have to travel home tomorrow so I need the help ASAP. Thanks
. I don't have a laptop that works at my access
