View Single Post
Old 12-21-2007, 10:51 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #11 (permalink)
yamaha4life89 Offline
Proven Member
yamaha4life89's Avatar
Tech Posts: 78
Classifieds Rating: 0
Reputation: yamaha4life89 is an unknown
depending on how much you know about cars you should beable to fix the stuff yourself there should be no reason why you should have to replace the motor unless it is shot. broken bolts and a bad throw out bearing doesnt mean you need a new motor. the main things i would be conserned about is getting the 2 fuel rail bolts out and replacing them. so that you can see how the car runs then worry about the axel if you cant get the bolts out for the bearing boostedtalonts had a good idea about using the fwd axel that would work the spindle sizes are the same for the fwd 1.8 2.0 and 2.0 turbo as the awd your just gonna have a litle bit of vibration and not have the extra support without the bearing. About the throw out bearing that not to big of a deal of replacing and while your in there u have the opertunity to replace the clutch with a aftermarket one.
