Since I was kept at the waiting list in my local turbo shop , I came upon a tuner who was shopping for turbos. I was going for a 57Trim , and was told that it wasnt in stock so I have to wait a week for garrett to ship in the turbos. The tuner instead was getting himself a
t3/t4 setup
t04s compressor housing
61mm inducer , exducer i couldnt measure for the compressor side
compressor antisurge holes like turbonetics style
but what concerned me most was Turbo Lag , that the reason i dint want to purchase anything above 57trim trim. I did ask for the tuners opinion , he said , the turbo he is purchasing runs on a divided 0.63 t3 turbine housing. And he does recommend to fabricate a turbular manifold that pulses cylinder 1-4 into one turbine inlet and 2-3 into the other turbine inlet of the divided housing. He also did say , the lag was bearable in a 2.0L car as he gets 23psi by 4000rpm.
Any opnion guys , i also did google it up , and found this article by turbobygarrett
The concept is to DIVIDE or separate the cylinders whose cycles interfere with one another to best utilize the engine's exhaust pulse energy.
For example, on a four-cylinder engine with firing order 1-3-4-2, cylinder #1 is ending its expansion stroke and opening its exhaust valve while cylinder #2 still has its exhaust valve open (cylinder #2 is in its overlap period). In an undivided exhaust manifold, this pressure pulse from cylinder #1's exhaust blowdown event is much more likely to contaminate cylinder #2 with high pressure exhaust gas. Not only does this hurt cylinder #2's ability to breathe properly, but this pulse energy would have been better utilized in the turbine.
The proper grouping for this engine is to keep complementary cylinders grouped together-- #1 and #4 are complementary; as are cylinders #2 and #3.
divided turbine housing
Figure 7. Illustration of divided turbine housing
