Hello, I have a question on a 1990 Turbo AWD swap to a 92 FWD N/T. I know for sure the gas tank has to be relocated & fuel lines as well. I have a 1990 GSX that I would like to transfer the AWD setup from to a 92 FWD Gs. Can this be done without too much headache. The 92 GS is in better shape body wise not adding its 2 yrs younger. I have already done the ECU wiring and currently using the 91-94 ECU with a dsmchip which was once in the 1990 GSX. If I have to FWD it I would like to use the AWD tranny and mod it using a limited Slip insert. What is envolved in doing the alterative if I have to go the FWD route if the AWD route is not possible?
Also thanks for the replies in advance.
