I have the GReddy intercooler piping kit with a GReddy Type-S BOV. The setup has worked great for me. One thing you might want to think about though is are you planning on upgrading to a FMIC any time soon? If so, the piping route might be different (e.g. short route) so you won't be able to use the upper IC piping with the new setup. Of course, this isn't always the case... for example I plan on purchasing the Hahn Racecraft FMIC for my 2g. This front mount uses the stock "long route" so it will work perfectly with my upper GReddy piping.
As far as the GReddy Type-RS BOV... yes, its a relatively new BOV. It was made to replace the GReddy Type-S. In all honesty, the two are fairly similar in function and form. One thing to note is that the old Type-S could be recirculated with no modifications, but the Type-RS requires an adapter to recirculate the BOV. Anyways, for what its worth my GReddy Type S has worked flawlessly for me. Its a solid BOV up to ~25psi.
____________________________
-Andrew
