Thread: ProSport Gauges
View Single Post
Old 08-28-2007, 12:21 PM   #68 (permalink)
devlish
Proven Member
devlish's Avatar
Classifieds Rating: (3)
Reputation: devlish is more helpful than not
under your dash in your ingnition wires you'll find a good ACCESORY wire to tap into. Your dimmer switch can be pulled from behind the radio, or by the button for the lights. always a good idea to fuse the power wire (in this case, between your ACC tap, and your guages)
another way to get a good ACC source, is to run an 8ga wire from the battery inside the car, and use a relay. use any small ACC wire to turn on the relay, then you can put quite a few ACC outlets off that relay, as long as you dont exceed the rating of the relay, usually 30a, if its a bosch relay. that gives you a good strong ACC source for multiple items. don't forget to fuse that 8ga with a 30amp fuse between the relay and the batt though.
good luck.
Offline
Sponsored Links
