As wret stated earlier, lowering springs on stock dampers isn't recommended. Why? The dampers can't handle the springs, and will wear out much, much sooner. Look around on the handling section of the forum, you'll see what others are running. The more research you do, the better off you'll be. It's better to wait and spend once on a good setup that you'll always be happy with. Sorry for rambling, just giving my $.02
