View Single Post
Old 08-14-2007, 03:13 PM   #2 (permalink)
hpram99
New Member/Lurker
Region: Midwest
Classifieds Rating: (0)
Reputation: hpram99 is an unknown
Yes, replacing the power steering pump is a 1 hour job.
Drain PS fluid.
Remove the belt.
Remove the low-pressure feed hose (bottom/side hose) from pump
Remove the high-pressure hose, making note of the order of washer, crush washers, and nut. Throw out the O-rings
Unplug Pressure Switch.
Remove the 5 bolts from the mount/PS pump
reinstall is reverse of removal
You'll need to re-tourqe them down to 21 ft/lbs, the adjustment bolt (long, skinny) is 16 ft/lbs.
Offline
[posts] Reply With Quote
Sponsored Links
