mmcd/PocketLogger accuracy... strange
Calan
DSM Wiseman
7,250
398
Jan 16, 2007
OKC, Oklahoma
I was playing around and just for giggles decided to switch from mmcd to PL while running some high temps the other night. MMCd was showing from around 216* to 223*, and PL was showing about 10 degrees cooler on average.
Any idea why they would be different, and which one is more accurate?
And if the coolant temps are this inaccurate with one of them, what else is out in left field?
I remembered that there was a change to the coolant interpolation tables but after checking I see that it was way back in 1.3b. MMCd should be producing the same values as DSMLink. Pocketlogger might produce the numbers as from the original TMO logger.
Unless you have a MUT or measure the actual coolant temp it will be hard to say who's correct.
