Quote:
Originally Posted by Steve93Talon
I was running the smaller wheel in the bolt-on housing, saw 30+psi before 4k and ran 11.9 @ 119 on pump at 27psi. Bear in mind that the small wheel is about the size of a P trim. I think it's a better match for a 2.0 than the big wheel.
I think you have that backwards the larger one is the size of a p trim which is a 74mm/64.5mm wheel. I would get the largest turbine wheel you can get with you getting a bolton turbine. The better your hotside flows the less boost it will take to make the same power.
