My 2g 6 Bolt Build
Here are some photos of the block and head before they were assembled. I will post pictures of the assembly as soon as I have some more time. Enjoy :thumb:
OK so I need some help. I have a brand new 6 bolt thermostat housing, I just took the 2g sensors out of my old thermostat housing last night. There is only 2 sensors on the 7 bolt housing so I swapped them into the 6 bolt housing. Now there is 3 more open spots on the 6 bolt housing below the thermostat and 1 opening above the thermostat. I'm wondering what is the best spot to put my aftermarket temp sender? I have seen other people install it below the thermostat and others above. I have a choice of either so I was wondering which would be the better spot? I can take pictures if needed.
hey nice work, I had a question for ya, wich head gasket are you using? and are you sprayin anything on it???
Vic
Vic
Thanks, I'm using the Cometic HP head gasket and no I did not spray anything on it. From the research I did, If your block and head were both machined then there is no need for spray. I guess I'll find out.
keep up the great work!
It brings back old memories to see another person going through the same thing with such meticulous practices and documentation...:thumb:
You'll be so happy very soon!
I went and worked on my motor today, I got alot done in the short amount of time I was there.
Can someone answer this for me, is this where the knock sensor goes on the back of the 6 bolt block?
Woops you where right its been a long time since I have seen the other side of the motor on my dsm and I was thinking honda which all together the wrong company.
That would be the wrong hole. See the hole that is right at the top of the block that is where you screw in the knock sensor.
Do you have a link to something that says thats where it goes? It just doesn't make sense to me. On my 7 bolt block it was right below the #2 cylinder so thats where I would assume it would be on the 6 bolt block? Thanks for the response.
A few more pictures with the valve cover on.
absolutely beautiful engine!
where did you get that spark plug cover and what did you pay for it by the way?
awesome work bro, hope mine turns out half as nice as yours
Thanks for the compliment. I bought the spark cover like 3 years ago so I don't remember where I got it from or how much I payed. But I can tell you one thing, I remember it was too much!
