Hey man,
Those are some pretty hefty numbers. I wouldn't go for anymore duration that what you are looking at now. If you feel after you have them on that you need more then by all means dial that in on the cam gears. As for the lift, are you shaving the head any? What's the comp again? I'm a little concerned about that much lift (.465) with the high rev that you were talking about doing. Did you check the geometry on that set-up? I'm concerned about the C3's hitting (though I'm going 12.1's with the .020 shave) much less the special grind that you are looking at.
MB
