Tuned for no knock. Logs inside, Have some Qs
90 TSI FWD
279
35
Oct 26, 2004
Vacaville, California
Car is a 1991 tsi awd. Main mods are: K&N, hard intake and IC piping w/ fmic, stock turbo spiking to 20psi and falling to 16, act2600, 4-bolt rear, 3" cutout after the downpipe [no cat], evoVIII 560cc injectors, and SAFC2 w/ logger.. thats it i think. pretty short list now that i think of it..
Anyway, I felt like tuning it today to get kid of the knock and finally did, but for some reason, the duty cycle is pretty darn high, dont you think? Why are they maxing out already, especially in the higher RPMs after the boost has dropped down to 16.
Now that I got rid of knock, how should I go about tuning for power? I decided to log the o2 reading and get somewhat of a clue as to where it runs rich/lean, but I dont really get the voltage.
When I went out to tune, the weather was 65 degrees, and when I came back, it was 70 outside. Will these tunes be thrown off once the weather is dropped like 30 degrees colder? would colder weather make the car richer or leaner?
1st run
2nd run
3rd run
Final corrections on the safc read [RPM/CORRECTION]:
Lo= 800/-29 1600/-29 2200/-22 2800/-20 3400/-20 4000/-20 4600/-20 5200/-20 5800/-20 6400/-20 7000/-20 7600/-20
Hi= 800/-29 1600/-29 2200/-19 2800/-18 3400/-18 4000/-20 4600/-19 5200/-19 5800/-19 6400/-17 7000/-20 7600/-20
this is for open exhaust.. closed is completely different because it's for stock boost
Thanks,
Chad
The Fact that you can't hold boost and your duty cycle is high makes me belive you have a big boost leak.
Do a leak test and also check for any exhaust leaks pre-turbo.
PS after you fix your leak your going to need to richen it up with the S-AFC.
How do I go about checking for exhaust leaks? I won't be able to do a boost leak for a while because I have no compressor and my friend, who does, is at work..
Pull off your heat shield and check all the manifold to head and manifold to turbo bolts and make sure there tight. Always if there are any black spots on the head or underside of the heatshield that is a dead giveaway.
I do have a 2" crack on the manifold though, but no noticable black spots and it doesnt seem like anything could get through it, maybe at 20psi, but i wouldnt be able to tell because the car pulls really hard. I'm going to do the boost leak later today around 6 and hope I'll find a problem [i really hope i dont but something's wrong somewhere]. The vacuum is always at -14 to -16 and has always been that way. My brother and I redid the timing belt to make sure it wasn't off, but it seemed like it never could get aligned perfectly, so its probably about a half a tooth off. could this throw something off?
What are the common places to find a big boost leak? We recently repainted the IC piping and used thicker coupler with rtv sealant to make sure there are no leaks at the couplers. The throttle body was replaced because the car wouldnt run right because there was a previous leak over there. we removed the intake manifold and sealed the gasket with sealant and tightened it down. The emissions were removed with no lines coming off of the throttle body and the EGR valve line was looped..
I did a boost leak test and the only one I found was a small one on the BISS screw.
I still have yet to find out why i'm spiking with a hallman es. "Now that I got rid of knock, how should I go about tuning for power? I decided to log the o2 reading and get somewhat of a clue as to where it runs rich/lean, but I dont really get the voltage.
When I went out to tune, the weather was 65 degrees, and when I came back, it was 70 outside. Will these tunes be thrown off once the weather is dropped like 30 degrees colder? would colder weather make the car richer or leaner?"
Also, is there an equation to change INJP to INJD? On my logger, it only says i have 75% max INJD, but when I put it on the computer, its 104?
When tuning by o2 Voltage remember, high voltage is rich, low volts is lean. I would aim for mid to high .8's
Tuning with a narrowband O2 sensor is worthless.
[QUOTE="90 TSI AWD]
[/quote]
IDC = [((IPW * RPM/60)/2)/1000] * 100
Narrowband o2 won't be as good as wideband setup, but it'll still get you close to where you want to be. Extreme has ngk wideband setup pretty cheap. I still need to put mine in, but for 200 ish its not bad.
IDC = ((IPW * RPM/60)/2)/1000
I wasn't tuning with a narrowband. I just decided to log o2 voltage to give me an idea on whether I'm running lean or rich.
Where did you get that equation from? I plugged that in on where excel said my IDC is 103 on my "3rd run" and I came up with .8055 which I'm guessing is 80.5%. Should I just ignore the 103 then?
That's about all the O2 is good for......an estimate. ;)
Not sure exactly. I have it in a Word document where I keep all kinds of stuff like that. The equation is correct, but you have to multiply by 100 to get a percent. I guess I should have put that in there instead of just copying and pasting from my Word document. Sorry about that. :coy:
You are correct, the 0.8055 should be multiplied by 100 to get percent. I'll go up and edit my previous post so that's in there.
As for the 103% that was the IDC at during that run, so you might want to look into some larger injectors, or turn down the boost. Can you post the results from your spreadsheet so I can take a look at them? It will save me from having to do the work myself. :p
1st run:
TIME ___________________ TIMA ________ ERPM ___________ KNCK ___ INJP ________ INJD
2000-01-02 07:18:21 ______ 26.00º ______ 1562.50rpm ______ 0 ______ 2.05ms ______ 3
2000-01-02 07:18:21 ______ 26.00º ______ 1562.50rpm ______ 0 ______ 2.30ms ______ 3
2000-01-02 07:18:21 ______ 26.00º ______ 1562.50rpm ______ 0 ______ 2.56ms ______ 4
2000-01-02 07:18:21 ______ 27.00º ______ 1593.75rpm ______ 0 ______ 2.56ms ______ 4
2000-01-02 07:18:21 ______ 27.00º ______ 1593.75rpm ______ 0 ______ 2.82ms ______ 4
2000-01-02 07:18:21 ______ 28.00º ______ 1593.75rpm ______ 0 ______ 3.07ms ______ 5
2000-01-02 07:18:21 ______ 27.00º ______ 1562.50rpm ______ 0 ______ 3.07ms ______ 5
2000-01-02 07:18:21 ______ 28.00º ______ 1593.75rpm ______ 0 ______ 3.33ms ______ 5
2000-01-02 07:18:21 ______ 29.00º ______ 1625.00rpm ______ 0 ______ 3.33ms ______ 5
2000-01-02 07:18:21 ______ 29.00º ______ 1656.25rpm ______ 0 ______ 3.33ms ______ 5
2000-01-02 07:18:22 ______ 28.00º ______ 1656.25rpm ______ 0 ______ 3.33ms ______ 5
2000-01-02 07:18:22 ______ 28.00º ______ 1687.50rpm ______ 0 ______ 3.58ms ______ 6
2000-01-02 07:18:22 ______ 27.00º ______ 1687.50rpm ______ 0 ______ 3.58ms ______ 6
2000-01-02 07:18:22 ______ 28.00º ______ 1750.00rpm ______ 0 ______ 3.58ms ______ 6
2000-01-02 07:18:22 ______ 28.00º ______ 1781.25rpm ______ 0 ______ 3.84ms ______ 7
2000-01-02 07:18:22 ______ 28.00º ______ 1812.50rpm ______ 0 ______ 4.10ms ______ 7
2000-01-02 07:18:22 ______ 27.00º ______ 1843.75rpm ______ 0 ______ 4.61ms ______ 9
2000-01-02 07:18:22 ______ 25.00º ______ 1875.00rpm ______ 0 ______ 4.86ms ______ 9
2000-01-02 07:18:22 ______ 25.00º ______ 1937.50rpm ______ 0 ______ 5.12ms ______ 10
2000-01-02 07:18:23 ______ 25.00º ______ 2031.25rpm ______ 0 ______ 5.12ms ______ 11
2000-01-02 07:18:23 ______ 25.00º ______ 2031.25rpm ______ 0 ______ 5.38ms ______ 11
2000-01-02 07:18:23 ______ 25.00º ______ 2093.75rpm ______ 0 ______ 5.63ms ______ 12
2000-01-02 07:18:23 ______ 25.00º ______ 2156.25rpm ______ 0 ______ 5.89ms ______ 13
2000-01-02 07:18:23 ______ 25.00º ______ 2218.75rpm ______ 0 ______ 6.66ms ______ 15
2000-01-02 07:18:23 ______ 25.00º ______ 2250.00rpm ______ 0 ______ 6.91ms ______ 16
2000-01-02 07:18:23 ______ 24.00º ______ 2281.25rpm ______ 0 ______ 6.91ms ______ 16
2000-01-02 07:18:23 ______ 24.00º ______ 2343.75rpm ______ 0 ______ 7.17ms ______ 17
2000-01-02 07:18:23 ______ 24.00º ______ 2406.25rpm ______ 0 ______ 7.42ms ______ 19
2000-01-02 07:18:23 ______ 24.00º ______ 2468.75rpm ______ 0 ______ 7.68ms ______ 20
2000-01-02 07:18:23 ______ 24.00º ______ 2531.25rpm ______ 0 ______ 7.68ms ______ 20
2000-01-02 07:18:24 ______ 23.00º ______ 2562.50rpm ______ 0 ______ 7.68ms ______ 21
2000-01-02 07:18:24 ______ 23.00º ______ 2625.00rpm ______ 0 ______ 7.94ms ______ 22
2000-01-02 07:18:24 ______ 23.00º ______ 2718.75rpm ______ 0 ______ 7.94ms ______ 23
2000-01-02 07:18:24 ______ 23.00º ______ 2750.00rpm ______ 4 ______ 8.45ms ______ 24
2000-01-02 07:18:24 ______ 21.00º ______ 2812.50rpm ______ 4 ______ 8.96ms ______ 26
2000-01-02 07:18:24 ______ 20.00º ______ 2906.25rpm ______ 4 ______ 9.47ms ______ 29
2000-01-02 07:18:24 ______ 20.00º ______ 2968.75rpm ______ 4 ______ 9.98ms ______ 31
2000-01-02 07:18:24 ______ 20.00º ______ 3031.25rpm ______ 3 ______ 10.75ms ______ 34
2000-01-02 07:18:24 ______ 20.00º ______ 3156.25rpm ______ 3 ______ 11.52ms ______ 38
2000-01-02 07:18:24 ______ 19.00º ______ 3187.50rpm ______ 3 ______ 12.29ms ______ 41
2000-01-02 07:18:24 ______ 18.00º ______ 3281.25rpm ______ 3 ______ 13.57ms ______ 47
2000-01-02 07:18:25 ______ 17.00º ______ 3406.25rpm ______ 3 ______ 14.85ms ______ 54
2000-01-02 07:18:25 ______ 16.00º ______ 3500.00rpm ______ 3 ______ 16.13ms ______ 60
2000-01-02 07:18:25 ______ 16.00º ______ 3531.25rpm ______ 3 ______ 17.15ms ______ 64
2000-01-02 07:18:25 ______ 16.00º ______ 3718.75rpm ______ 2 ______ 18.18ms ______ 72
2000-01-02 07:18:25 ______ 16.00º ______ 3781.25rpm ______ 2 ______ 18.94ms ______ 76
2000-01-02 07:18:25 ______ 17.00º ______ 3875.00rpm ______ 2 ______ 18.69ms ______ 77
2000-01-02 07:18:25 ______ 17.00º ______ 3937.50rpm ______ 2 ______ 17.92ms ______ 75
2000-01-02 07:18:25 ______ 17.00º ______ 4218.75rpm ______ 2 ______ 17.66ms ______ 79
2000-01-02 07:18:25 ______ 18.00º ______ 4406.25rpm ______ 6 ______ 17.15ms ______ 80
2000-01-02 07:18:25 ______ 17.00º ______ 4531.25rpm ______ 5 ______ 16.90ms ______ 81
2000-01-02 07:18:26 ______ 17.00º ______ 4593.75rpm ______ 5 ______ 16.90ms ______ 82
2000-01-02 07:18:26 ______ 17.00º ______ 4625.00rpm ______ 5 ______ 16.90ms ______ 83
2000-01-02 07:18:26 ______ 17.00º ______ 4812.50rpm ______ 5 ______ 17.41ms ______ 89
2000-01-02 07:18:26 ______ 16.00º ______ 4968.75rpm ______ 5 ______ 17.41ms ______ 92
2000-01-02 07:18:26 ______ 16.00º ______ 5093.75rpm ______ 5 ______ 16.90ms ______ 91
2000-01-02 07:18:26 ______ 16.00º ______ 5125.00rpm ______ 4 ______ 16.90ms ______ 92
2000-01-02 07:18:26 ______ 18.00º ______ 5375.00rpm ______ 4 ______ 16.38ms ______ 94
2000-01-02 07:18:26 ______ 18.00º ______ 5343.75rpm ______ 4 ______ 16.13ms ______ 92
2000-01-02 07:18:26 ______ 20.00º ______ 5500.00rpm ______ 4 ______ 16.38ms ______ 96
2000-01-02 07:18:26 ______ 20.00º ______ 5718.75rpm ______ 4 ______ 15.87ms ______ 96
2000-01-02 07:18:27 ______ 20.00º ______ 5656.25rpm ______ 4 ______ 15.62ms ______ 94
2000-01-02 07:18:27 ______ 21.00º ______ 5843.75rpm ______ 3 ______ 15.62ms ______ 97
2000-01-02 07:18:27 ______ 22.00º ______ 5937.50rpm ______ 3 ______ 15.36ms ______ 97
2000-01-02 07:18:27 ______ 23.00º ______ 6125.00rpm ______ 4 ______ 15.10ms ______ 98
2000-01-02 07:18:27 ______ 22.00º ______ 6093.75rpm ______ 4 ______ 14.34ms ______ 93
2000-01-02 07:18:27 ______ 22.00º ______ 6156.25rpm ______ 4 ______ 14.34ms ______ 94
2000-01-02 07:18:27 ______ 23.00º ______ 6218.75rpm ______ 4 ______ 14.08ms ______ 93
2000-01-02 07:18:27 ______ 22.00º ______ 6406.25rpm ______ 3 ______ 14.85ms ______ 101
2000-01-02 07:18:27 ______ 21.00º ______ 6406.25rpm ______ 3 ______ 13.57ms ______ 92
2000-01-02 07:18:27 ______ 24.00º ______ 6593.75rpm ______ 3 ______ 13.57ms ______ 95
2000-01-02 07:18:27 ______ 23.00º ______ 6656.25rpm ______ 3 ______ 13.57ms ______ 96
2000-01-02 07:18:28 ______ 21.00º ______ 6718.75rpm ______ 3 ______ 13.31ms ______ 95
2000-01-02 07:18:28 ______ 22.00º ______ 6781.25rpm ______ 3 ______ 13.31ms ______ 96
2000-01-02 07:18:28 ______ 20.00º ______ 6812.50rpm ______ 3 ______ 13.31ms ______ 96
2000-01-02 07:18:28 ______ 21.00º ______ 6875.00rpm ______ 2 ______ 12.80ms ______ 94
2000-01-02 07:18:28 ______ 22.00º ______ 6937.50rpm ______ 2 ______ 13.06ms ______ 96
2000-01-02 07:18:28 ______ 20.00º ______ 7000.00rpm ______ 2 ______ 12.54ms ______ 93
2000-01-02 07:18:28 ______ 20.00º ______ 7156.25rpm ______ 2 ______ 5.38ms ______ 41
2000-01-02 07:18:28 ______ 35.00º ______ 6750.00rpm ______ 0 ______ 2.30ms ______ 16
2000-01-02 07:18:28 ______ 45.00º ______ 6531.25rpm ______ 0 ______ 1.28ms ______ 8
2000-01-02 07:18:28 ______ 45.00º ______ 6375.00rpm ______ 0 ______ 1.54ms ______ 10
2000-01-02 07:18:28 ______ 45.00º ______ 6093.75rpm ______ 0 ______ 1.28ms ______ 8
2nd Run:
2000-01-02 07:21:37 ______ 26.00º ______ 1531.25rpm ______ 0 ______ 2.82ms ______ 4
2000-01-02 07:21:37 ______ 27.00º ______ 1531.25rpm ______ 0 ______ 3.07ms ______ 5
2000-01-02 07:21:37 ______ 28.00º ______ 1562.50rpm ______ 0 ______ 3.33ms ______ 5
2000-01-02 07:21:37 ______ 27.00º ______ 1562.50rpm ______ 0 ______ 3.58ms ______ 5
2000-01-02 07:21:37 ______ 26.00º ______ 1625.00rpm ______ 0 ______ 3.84ms ______ 6
2000-01-02 07:21:37 ______ 26.00º ______ 1625.00rpm ______ 0 ______ 4.10ms ______ 7
2000-01-02 07:21:37 ______ 25.00º ______ 1593.75rpm ______ 0 ______ 4.10ms ______ 6
2000-01-02 07:21:37 ______ 25.00º ______ 1687.50rpm ______ 0 ______ 3.84ms ______ 6
2000-01-02 07:21:38 ______ 26.00º ______ 1656.25rpm ______ 0 ______ 3.84ms ______ 6
2000-01-02 07:21:38 ______ 26.00º ______ 1687.50rpm ______ 0 ______ 3.84ms ______ 6
2000-01-02 07:21:38 ______ 27.00º ______ 1750.00rpm ______ 0 ______ 3.84ms ______ 7
2000-01-02 07:21:38 ______ 26.00º ______ 1718.75rpm ______ 0 ______ 4.10ms ______ 7
2000-01-02 07:21:38 ______ 27.00º ______ 1812.50rpm ______ 0 ______ 4.10ms ______ 7
2000-01-02 07:21:38 ______ 27.00º ______ 1843.75rpm ______ 0 ______ 4.10ms ______ 8
2000-01-02 07:21:38 ______ 28.00º ______ 1875.00rpm ______ 0 ______ 4.10ms ______ 8
2000-01-02 07:21:38 ______ 28.00º ______ 1937.50rpm ______ 0 ______ 4.10ms ______ 8
2000-01-02 07:21:38 ______ 28.00º ______ 1968.75rpm ______ 0 ______ 4.10ms ______ 8
2000-01-02 07:21:38 ______ 27.00º ______ 2000.00rpm ______ 0 ______ 4.61ms ______ 9
2000-01-02 07:21:38 ______ 26.00º ______ 2031.25rpm ______ 0 ______ 4.86ms ______ 10
2000-01-02 07:21:39 ______ 26.00º ______ 2031.25rpm ______ 0 ______ 5.12ms ______ 11
2000-01-02 07:21:39 ______ 25.00º ______ 2125.00rpm ______ 0 ______ 5.12ms ______ 11
2000-01-02 07:21:39 ______ 26.00º ______ 2125.00rpm ______ 0 ______ 5.12ms ______ 11
2000-01-02 07:21:39 ______ 26.00º ______ 2187.50rpm ______ 0 ______ 4.86ms ______ 11
2000-01-02 07:21:39 ______ 26.00º ______ 2218.75rpm ______ 0 ______ 5.12ms ______ 12
2000-01-02 07:21:39 ______ 26.00º ______ 2250.00rpm ______ 0 ______ 5.12ms ______ 12
2000-01-02 07:21:39 ______ 26.00º ______ 2312.50rpm ______ 0 ______ 5.12ms ______ 12
2000-01-02 07:21:39 ______ 26.00º ______ 2375.00rpm ______ 0 ______ 5.12ms ______ 12
2000-01-02 07:21:39 ______ 27.00º ______ 2375.00rpm ______ 0 ______ 5.12ms ______ 12
2000-01-02 07:21:39 ______ 26.00º ______ 2406.25rpm ______ 0 ______ 5.12ms ______ 13
2000-01-02 07:21:39 ______ 24.00º ______ 2468.75rpm ______ 4 ______ 5.38ms ______ 14
2000-01-02 07:21:40 ______ 23.00º ______ 2531.25rpm ______ 3 ______ 5.63ms ______ 15
2000-01-02 07:21:40 ______ 24.00º ______ 2562.50rpm ______ 3 ______ 7.42ms ______ 20
2000-01-02 07:21:40 ______ 23.00º ______ 2625.00rpm ______ 7 ______ 7.68ms ______ 21
2000-01-02 07:21:40 ______ 21.00º ______ 2687.50rpm ______ 7 ______ 7.94ms ______ 22
2000-01-02 07:21:40 ______ 20.00º ______ 2718.75rpm ______ 7 ______ 8.19ms ______ 23
2000-01-02 07:21:40 ______ 20.00º ______ 2812.50rpm ______ 7 ______ 8.45ms ______ 25
2000-01-02 07:21:40 ______ 20.00º ______ 2843.75rpm ______ 7 ______ 8.96ms ______ 27
2000-01-02 07:21:40 ______ 19.00º ______ 2906.25rpm ______ 6 ______ 9.73ms ______ 30
2000-01-02 07:21:40 ______ 20.00º ______ 3000.00rpm ______ 6 ______ 9.98ms ______ 32
2000-01-02 07:21:40 ______ 20.00º ______ 3062.50rpm ______ 6 ______ 10.75ms ______ 35
2000-01-02 07:21:40 ______ 19.00º ______ 3093.75rpm ______ 6 ______ 11.52ms ______ 38
2000-01-02 07:21:41 ______ 18.00º ______ 3218.75rpm ______ 6 ______ 12.29ms ______ 42
2000-01-02 07:21:41 ______ 17.00º ______ 3218.75rpm ______ 6 ______ 13.31ms ______ 45
2000-01-02 07:21:41 ______ 16.00º ______ 3343.75rpm ______ 5 ______ 14.59ms ______ 52
2000-01-02 07:21:41 ______ 16.00º ______ 3468.75rpm ______ 5 ______ 15.62ms ______ 57
2000-01-02 07:21:41 ______ 15.00º ______ 3531.25rpm ______ 5 ______ 16.90ms ______ 63
2000-01-02 07:21:41 ______ 15.00º ______ 3656.25rpm ______ 5 ______ 17.92ms ______ 70
2000-01-02 07:21:41 ______ 15.00º ______ 3750.00rpm ______ 5 ______ 18.69ms ______ 74
2000-01-02 07:21:41 ______ 16.00º ______ 3906.25rpm ______ 5 ______ 18.69ms ______ 77
2000-01-02 07:21:41 ______ 16.00º ______ 4031.25rpm ______ 4 ______ 17.66ms ______ 76
2000-01-02 07:21:41 ______ 15.00º ______ 4156.25rpm ______ 8 ______ 17.92ms ______ 79
2000-01-02 07:21:42 ______ 16.00º ______ 4281.25rpm ______ 8 ______ 17.66ms ______ 80
2000-01-02 07:21:42 ______ 16.00º ______ 4437.50rpm ______ 8 ______ 16.90ms ______ 80
2000-01-02 07:21:42 ______ 16.00º ______ 4625.00rpm ______ 8 ______ 17.41ms ______ 86
2000-01-02 07:21:42 ______ 16.00º ______ 4687.50rpm ______ 8 ______ 17.15ms ______ 85
2000-01-02 07:21:42 ______ 16.00º ______ 4843.75rpm ______ 7 ______ 17.15ms ______ 88
2000-01-02 07:21:42 ______ 15.00º ______ 4906.25rpm ______ 7 ______ 16.64ms ______ 87
2000-01-02 07:21:42 ______ 15.00º ______ 5125.00rpm ______ 7 ______ 16.90ms ______ 92
2000-01-02 07:21:42 ______ 16.00º ______ 5156.25rpm ______ 7 ______ 16.90ms ______ 93
2000-01-02 07:21:42 ______ 16.00º ______ 5093.75rpm ______ 7 ______ 16.64ms ______ 90
2000-01-02 07:21:42 ______ 16.00º ______ 5312.50rpm ______ 7 ______ 16.64ms ______ 94
2000-01-02 07:21:43 ______ 17.00º ______ 5406.25rpm ______ 6 ______ 16.13ms ______ 93
2000-01-02 07:21:43 ______ 19.00º ______ 5593.75rpm ______ 6 ______ 16.13ms ______ 96
2000-01-02 07:21:43 ______ 19.00º ______ 5656.25rpm ______ 6 ______ 14.85ms ______ 89
2000-01-02 07:21:43 ______ 22.00º ______ 5718.75rpm ______ 6 ______ 14.59ms ______ 89
2000-01-02 07:21:43 ______ 21.00º ______ 5750.00rpm ______ 6 ______ 15.10ms ______ 92
2000-01-02 07:21:43 ______ 22.00º ______ 5843.75rpm ______ 7 ______ 15.10ms ______ 94
2000-01-02 07:21:43 ______ 20.00º ______ 6000.00rpm ______ 6 ______ 15.36ms ______ 98
2000-01-02 07:21:43 ______ 20.00º ______ 6218.75rpm ______ 6 ______ 14.08ms ______ 93
2000-01-02 07:21:43 ______ 23.00º ______ 6187.50rpm ______ 6 ______ 14.08ms ______ 93
2000-01-02 07:21:43 ______ 21.00º ______ 6218.75rpm ______ 6 ______ 14.34ms ______ 95
2000-01-02 07:21:43 ______ 22.00º ______ 6406.25rpm ______ 6 ______ 14.08ms ______ 96
2000-01-02 07:21:44 ______ 20.00º ______ 6281.25rpm ______ 6 ______ 14.85ms ______ 99
2000-01-02 07:21:44 ______ 19.00º ______ 6531.25rpm ______ 6 ______ 14.34ms ______ 100
2000-01-02 07:21:44 ______ 19.00º ______ 6593.75rpm ______ 5 ______ 14.85ms ______ 104
2000-01-02 07:21:44 ______ 19.00º ______ 6531.25rpm ______ 5 ______ 13.57ms ______ 94
2000-01-02 07:21:44 ______ 20.00º ______ 6875.00rpm ______ 5 ______ 11.01ms ______ 80
2000-01-02 07:21:44 ______ 21.00º ______ 6812.50rpm ______ 5 ______ 13.82ms ______ 100
2000-01-02 07:21:44 ______ 20.00º ______ 6718.75rpm ______ 5 ______ 13.31ms ______ 95
2000-01-02 07:21:44 ______ 20.00º ______ 6875.00rpm ______ 5 ______ 9.73ms ______ 71
2000-01-02 07:21:44 ______ 20.00º ______ 6656.25rpm ______ 4 ______ 1.54ms ______ 10
2000-01-02 07:21:44 ______ 40.00º ______ 6562.50rpm ______ 0 ______ 1.79ms ______ 12
2000-01-02 07:21:45 ______ 45.00º ______ 6593.75rpm ______ 0 ______ 1.28ms ______ 9
2000-01-02 07:21:45 ______ 45.00º ______ 6375.00rpm ______ 0 ______ 1.28ms ______ 8
2000-01-02 07:21:45 ______ 45.00º ______ 6031.25rpm ______ 0 ______ 1.28ms ______ 8
2000-01-02 07:21:45 ______ 45.00º ______ 5718.75rpm ______ 0 ______ 1.28ms ______ 7
2000-01-02 07:21:45 ______ 45.00º ______ 5593.75rpm ______ 0 ______ 1.28ms ______ 7
2000-01-02 07:21:45 ______ 45.00º ______ 5312.50rpm ______ 0 ______ 1.28ms ______ 7
2000-01-02 07:21:45 ______ 45.00º ______ 5062.50rpm ______ 0 ______ 1.28ms ______ 6
2000-01-02 07:21:45 ______ 45.00º ______ 4968.75rpm ______ 0 ______ 0.00ms ______ 0
2000-01-02 07:21:45 ______ 32.00º ______ 4843.75rpm ______ 0 ______ 0.00ms ______ 0
3rd Run:
TIME ___________________ TIMA ________ O2-R _______ ERPM ___________ KNCK ___ INJP ________ INJD
2000-01-02 07:25:45 ______ 15.00º ______ 0.00V ______ 1125.00rpm ______ 0 ______ 2.05ms ______ 2
2000-01-02 07:25:45 ______ 16.00º ______ 0.00V ______ 1187.50rpm ______ 0 ______ 2.05ms ______ 2
2000-01-02 07:25:45 ______ 19.00º ______ 0.00V ______ 1281.25rpm ______ 0 ______ 2.30ms ______ 3
2000-01-02 07:25:45 ______ 21.00º ______ 0.00V ______ 1343.75rpm ______ 0 ______ 2.30ms ______ 3
2000-01-02 07:25:45 ______ 21.00º ______ 0.02V ______ 1281.25rpm ______ 0 ______ 2.56ms ______ 3
2000-01-02 07:25:45 ______ 20.00º ______ 0.04V ______ 1250.00rpm ______ 0 ______ 2.56ms ______ 3
2000-01-02 07:25:45 ______ 20.00º ______ 0.04V ______ 1250.00rpm ______ 0 ______ 2.82ms ______ 3
2000-01-02 07:25:45 ______ 20.00º ______ 0.06V ______ 1281.25rpm ______ 0 ______ 3.07ms ______ 4
2000-01-02 07:25:46 ______ 22.00º ______ 0.16V ______ 1312.50rpm ______ 0 ______ 3.07ms ______ 4
2000-01-02 07:25:46 ______ 23.00º ______ 0.04V ______ 1312.50rpm ______ 0 ______ 3.33ms ______ 4
2000-01-02 07:25:46 ______ 23.00º ______ 0.02V ______ 1343.75rpm ______ 0 ______ 3.58ms ______ 5
2000-01-02 07:25:46 ______ 23.00º ______ 0.04V ______ 1375.00rpm ______ 0 ______ 3.84ms ______ 5
2000-01-02 07:25:46 ______ 23.00º ______ 0.02V ______ 1406.25rpm ______ 0 ______ 3.84ms ______ 5
2000-01-02 07:25:46 ______ 23.00º ______ 0.39V ______ 1437.50rpm ______ 0 ______ 3.84ms ______ 5
2000-01-02 07:25:46 ______ 24.00º ______ 0.76V ______ 1468.75rpm ______ 0 ______ 3.84ms ______ 6
2000-01-02 07:25:46 ______ 24.00º ______ 0.80V ______ 1500.00rpm ______ 0 ______ 3.84ms ______ 6
2000-01-02 07:25:46 ______ 24.00º ______ 0.82V ______ 1531.25rpm ______ 0 ______ 3.84ms ______ 6
2000-01-02 07:25:46 ______ 25.00º ______ 0.82V ______ 1562.50rpm ______ 0 ______ 3.58ms ______ 5
2000-01-02 07:25:47 ______ 25.00º ______ 0.82V ______ 1593.75rpm ______ 0 ______ 3.58ms ______ 6
2000-01-02 07:25:47 ______ 26.00º ______ 0.82V ______ 1656.25rpm ______ 0 ______ 3.58ms ______ 6
2000-01-02 07:25:47 ______ 27.00º ______ 0.82V ______ 1687.50rpm ______ 0 ______ 3.58ms ______ 6
2000-01-02 07:25:47 ______ 27.00º ______ 0.80V ______ 1687.50rpm ______ 0 ______ 3.58ms ______ 6
2000-01-02 07:25:47 ______ 28.00º ______ 0.80V ______ 1750.00rpm ______ 0 ______ 3.58ms ______ 6
2000-01-02 07:25:47 ______ 28.00º ______ 0.78V ______ 1781.25rpm ______ 0 ______ 3.58ms ______ 6
2000-01-02 07:25:47 ______ 29.00º ______ 0.76V ______ 1812.50rpm ______ 0 ______ 3.58ms ______ 6
2000-01-02 07:25:47 ______ 29.00º ______ 0.78V ______ 1843.75rpm ______ 0 ______ 3.58ms ______ 7
2000-01-02 07:25:47 ______ 30.00º ______ 0.78V ______ 1875.00rpm ______ 0 ______ 3.33ms ______ 6
2000-01-02 07:25:47 ______ 30.00º ______ 0.78V ______ 1906.25rpm ______ 0 ______ 3.33ms ______ 6
2000-01-02 07:25:47 ______ 31.00º ______ 0.76V ______ 1937.50rpm ______ 1 ______ 3.33ms ______ 6
2000-01-02 07:25:48 ______ 29.00º ______ 0.76V ______ 1968.75rpm ______ 0 ______ 3.58ms ______ 7
2000-01-02 07:25:48 ______ 30.00º ______ 0.33V ______ 2000.00rpm ______ 0 ______ 4.10ms ______ 8
2000-01-02 07:25:48 ______ 28.00º ______ 0.02V ______ 2062.50rpm ______ 0 ______ 4.61ms ______ 10
2000-01-02 07:25:48 ______ 26.00º ______ 0.04V ______ 2093.75rpm ______ 0 ______ 4.86ms ______ 10
2000-01-02 07:25:48 ______ 27.00º ______ 0.10V ______ 2156.25rpm ______ 0 ______ 5.12ms ______ 11
2000-01-02 07:25:48 ______ 26.00º ______ 0.72V ______ 2187.50rpm ______ 0 ______ 5.38ms ______ 12
2000-01-02 07:25:48 ______ 25.00º ______ 0.82V ______ 2281.25rpm ______ 0 ______ 5.63ms ______ 13
2000-01-02 07:25:48 ______ 25.00º ______ 0.84V ______ 2312.50rpm ______ 0 ______ 6.66ms ______ 16
2000-01-02 07:25:48 ______ 24.00º ______ 0.86V ______ 2406.25rpm ______ 0 ______ 7.17ms ______ 18
2000-01-02 07:25:49 ______ 24.00º ______ 0.88V ______ 2500.00rpm ______ 0 ______ 7.17ms ______ 19
2000-01-02 07:25:49 ______ 24.00º ______ 0.88V ______ 2562.50rpm ______ 0 ______ 7.68ms ______ 21
2000-01-02 07:25:49 ______ 23.00º ______ 0.90V ______ 2593.75rpm ______ 0 ______ 7.94ms ______ 21
2000-01-02 07:25:49 ______ 23.00º ______ 0.90V ______ 2718.75rpm ______ 0 ______ 7.94ms ______ 23
2000-01-02 07:25:49 ______ 23.00º ______ 0.90V ______ 2781.25rpm ______ 0 ______ 8.45ms ______ 25
2000-01-02 07:25:49 ______ 22.00º ______ 0.90V ______ 2875.00rpm ______ 0 ______ 8.96ms ______ 27
2000-01-02 07:25:49 ______ 22.00º ______ 0.90V ______ 2968.75rpm ______ 0 ______ 9.47ms ______ 30
2000-01-02 07:25:49 ______ 22.00º ______ 0.90V ______ 3062.50rpm ______ 0 ______ 10.24ms ______ 33
2000-01-02 07:25:49 ______ 21.00º ______ 0.90V ______ 3156.25rpm ______ 0 ______ 11.01ms ______ 37
2000-01-02 07:25:50 ______ 20.00º ______ 0.90V ______ 3218.75rpm ______ 0 ______ 12.03ms ______ 41
2000-01-02 07:25:50 ______ 19.00º ______ 0.90V ______ 3375.00rpm ______ 0 ______ 13.82ms ______ 49
2000-01-02 07:25:50 ______ 18.00º ______ 0.90V ______ 3500.00rpm ______ 0 ______ 15.10ms ______ 56
2000-01-02 07:25:50 ______ 17.00º ______ 0.90V ______ 3625.00rpm ______ 0 ______ 16.38ms ______ 63
2000-01-02 07:25:50 ______ 17.00º ______ 0.90V ______ 3718.75rpm ______ 0 ______ 17.66ms ______ 70
2000-01-02 07:25:50 ______ 18.00º ______ 0.88V ______ 3781.25rpm ______ 0 ______ 18.69ms ______ 75
2000-01-02 07:25:50 ______ 18.00º ______ 0.88V ______ 4000.00rpm ______ 0 ______ 18.43ms ______ 78
2000-01-02 07:25:50 ______ 18.00º ______ 0.88V ______ 4187.50rpm ______ 0 ______ 17.92ms ______ 80
2000-01-02 07:25:51 ______ 19.00º ______ 0.86V ______ 4343.75rpm ______ 0 ______ 16.90ms ______ 78
2000-01-02 07:25:51 ______ 19.00º ______ 0.86V ______ 4625.00rpm ______ 0 ______ 17.41ms ______ 86
2000-01-02 07:25:51 ______ 18.00º ______ 0.86V ______ 4812.50rpm ______ 0 ______ 17.15ms ______ 88
2000-01-02 07:25:51 ______ 18.00º ______ 0.86V ______ 4968.75rpm ______ 0 ______ 16.64ms ______ 88
2000-01-02 07:25:51 ______ 18.00º ______ 0.86V ______ 5250.00rpm ______ 0 ______ 16.38ms ______ 91
2000-01-02 07:25:51 ______ 19.00º ______ 0.86V ______ 5406.25rpm ______ 0 ______ 16.38ms ______ 94
2000-01-02 07:25:51 ______ 21.00º ______ 0.86V ______ 5437.50rpm ______ 0 ______ 15.87ms ______ 92
2000-01-02 07:25:52 ______ 21.00º ______ 0.86V ______ 5562.50rpm ______ 0 ______ 15.87ms ______ 94
2000-01-02 07:25:52 ______ 22.00º ______ 0.86V ______ 5750.00rpm ______ 0 ______ 15.62ms ______ 95
2000-01-02 07:25:52 ______ 23.00º ______ 0.86V ______ 5812.50rpm ______ 0 ______ 15.62ms ______ 96
2000-01-02 07:25:52 ______ 23.00º ______ 0.86V ______ 5937.50rpm ______ 0 ______ 15.10ms ______ 95
2000-01-02 07:25:52 ______ 23.00º ______ 0.86V ______ 6093.75rpm ______ 0 ______ 14.85ms ______ 96
2000-01-02 07:25:52 ______ 23.00º ______ 0.86V ______ 6156.25rpm ______ 0 ______ 14.34ms ______ 94
2000-01-02 07:25:52 ______ 22.00º ______ 0.86V ______ 6312.50rpm ______ 0 ______ 14.34ms ______ 96
2000-01-02 07:25:52 ______ 23.00º ______ 0.86V ______ 6281.25rpm ______ 0 ______ 13.31ms ______ 89
2000-01-02 07:25:53 ______ 24.00º ______ 0.86V ______ 6593.75rpm ______ 0 ______ 13.82ms ______ 97
2000-01-02 07:25:53 ______ 23.00º ______ 0.86V ______ 6625.00rpm ______ 0 ______ 14.59ms ______ 103
2000-01-02 07:25:53 ______ 21.00º ______ 0.86V ______ 6531.25rpm ______ 1 ______ 13.82ms ______ 96
2000-01-02 07:25:53 ______ 21.00º ______ 0.86V ______ 6718.75rpm ______ 1 ______ 13.57ms ______ 97
2000-01-02 07:25:53 ______ 21.00º ______ 0.86V ______ 6718.75rpm ______ 0 ______ 13.06ms ______ 93
2000-01-02 07:25:53 ______ 21.00º ______ 0.86V ______ 6781.25rpm ______ 0 ______ 2.05ms ______ 14
2000-01-02 07:25:53 ______ 39.00º ______ 0.78V ______ 6531.25rpm ______ 0 ______ 1.54ms ______ 10
2000-01-02 07:25:53 ______ 45.00º ______ 0.86V ______ 6343.75rpm ______ 0 ______ 1.28ms ______ 8
2000-01-02 07:25:53 ______ 45.00º ______ 0.74V ______ 6062.50rpm ______ 0 ______ 1.54ms ______ 9
2000-01-02 07:25:54 ______ 45.00º ______ 0.68V ______ 5593.75rpm ______ 0 ______ 1.28ms ______ 7
2000-01-02 07:25:54 ______ 45.00º ______ 0.76V ______ 5375.00rpm ______ 0 ______ 1.28ms ______ 7
2000-01-02 07:25:54 ______ 45.00º ______ 0.84V ______ 5125.00rpm ______ 0 ______ 1.28ms ______ 7
2000-01-02 07:25:54 ______ 45.00º ______ 0.82V ______ 5000.00rpm ______ 0 ______ 1.28ms ______ 6
2000-01-02 07:25:54 ______ 45.00º ______ 0.82V ______ 4812.50rpm ______ 0 ______ 0.00ms ______ 0
2000-01-02 07:25:54 ______ 31.00º ______ 0.74V ______ 4656.25rpm ______ 0 ______ 0.00ms ______ 0
2000-01-02 07:25:54 ______ 31.00º ______ 0.02V ______ 4343.75rpm ______ 0 ______ 0.00ms ______ 0
2000-01-02 07:25:54 ______ 30.00º ______ 0.00V ______ 4156.25rpm ______ 0 ______ 0.00ms ______ 0
2000-01-02 07:25:54 ______ 28.00º ______ 0.00V ______ 3937.50rpm ______ 0 ______ 0.00ms ______ 0
2000-01-02 07:25:55 ______ 28.00º ______ 0.00V ______ 3718.75rpm ______ 0 ______ 0.00ms ______ 0
2000-01-02 07:25:55 ______ 27.00º ______ 0.00V ______ 3593.75rpm ______ 0 ______ 0.00ms ______ 0
4th Run:
TIME ___________________ TIMA ________ O2-R _______ ERPM ___ KNCK ___ INJP ________ INJD
2000-01-02 08:06:13 ______ 10.00º ______ 0.72V ______ 812.50rpm ______ 0 ______ 1.79ms ______ 1
2000-01-02 08:06:13 ______ 8.00º ______ 0.78V ______ 812.50rpm ______ 0 ______ 1.79ms ______ 1
2000-01-02 08:06:14 ______ 8.00º ______ 0.57V ______ 812.50rpm ______ 0 ______ 1.79ms ______ 1
2000-01-02 08:06:14 ______ 8.00º ______ 0.60V ______ 781.25rpm ______ 0 ______ 1.79ms ______ 1
2000-01-02 08:06:14 ______ 11.00º ______ 0.31V ______ 781.25rpm ______ 0 ______ 1.79ms ______ 1
2000-01-02 08:06:14 ______ 10.00º ______ 0.06V ______ 812.50rpm ______ 0 ______ 1.79ms ______ 1
2000-01-02 08:06:14 ______ 9.00º ______ 0.08V ______ 781.25rpm ______ 0 ______ 1.79ms ______ 1
2000-01-02 08:06:14 ______ 9.00º ______ 0.04V ______ 781.25rpm ______ 0 ______ 1.79ms ______ 1
2000-01-02 08:06:14 ______ 9.00º ______ 0.06V ______ 781.25rpm ______ 0 ______ 1.79ms ______ 1
2000-01-02 08:06:14 ______ 8.00º ______ 0.18V ______ 781.25rpm ______ 0 ______ 1.79ms ______ 1
2000-01-02 08:06:14 ______ 10.00º ______ 0.51V ______ 781.25rpm ______ 0 ______ 1.79ms ______ 1
2000-01-02 08:06:14 ______ 8.00º ______ 0.29V ______ 781.25rpm ______ 0 ______ 2.05ms ______ 1
2000-01-02 08:06:15 ______ 8.00º ______ 0.66V ______ 781.25rpm ______ 0 ______ 2.30ms ______ 1
2000-01-02 08:06:15 ______ 7.00º ______ 0.20V ______ 781.25rpm ______ 0 ______ 2.56ms ______ 2
2000-01-02 08:06:15 ______ 6.00º ______ 0.06V ______ 812.50rpm ______ 0 ______ 2.56ms ______ 2
2000-01-02 08:06:15 ______ 7.00º ______ 0.02V ______ 781.25rpm ______ 0 ______ 2.56ms ______ 2
2000-01-02 08:06:15 ______ 7.00º ______ 0.00V ______ 875.00rpm ______ 0 ______ 2.56ms ______ 2
2000-01-02 08:06:15 ______ 8.00º ______ 0.00V ______ 937.50rpm ______ 0 ______ 2.56ms ______ 2
2000-01-02 08:06:15 ______ 9.00º ______ 0.00V ______ 906.25rpm ______ 0 ______ 2.82ms ______ 2
2000-01-02 08:06:15 ______ 8.00º ______ 0.00V ______ 906.25rpm ______ 0 ______ 2.82ms ______ 2
2000-01-02 08:06:15 ______ 9.00º ______ 0.00V ______ 843.75rpm ______ 0 ______ 3.07ms ______ 2
2000-01-02 08:06:16 ______ 9.00º ______ 0.00V ______ 843.75rpm ______ 0 ______ 3.07ms ______ 2
2000-01-02 08:06:16 ______ 8.00º ______ 0.00V ______ 843.75rpm ______ 0 ______ 3.07ms ______ 2
2000-01-02 08:06:16 ______ 10.00º ______ 0.00V ______ 843.75rpm ______ 0 ______ 3.07ms ______ 2
2000-01-02 08:06:16 ______ 11.00º ______ 0.00V ______ 875.00rpm ______ 0 ______ 3.07ms ______ 2
2000-01-02 08:06:16 ______ 12.00º ______ 0.00V ______ 968.75rpm ______ 0 ______ 3.07ms ______ 3
2000-01-02 08:06:16 ______ 14.00º ______ 0.00V ______ 1031.25rpm ______ 0 ______ 3.07ms ______ 3
2000-01-02 08:06:16 ______ 15.00º ______ 0.00V ______ 1093.75rpm ______ 0 ______ 3.07ms ______ 3
2000-01-02 08:06:16 ______ 17.00º ______ 0.00V ______ 1156.25rpm ______ 0 ______ 3.07ms ______ 3
2000-01-02 08:06:16 ______ 20.00º ______ 0.00V ______ 1218.75rpm ______ 0 ______ 3.33ms ______ 4
2000-01-02 08:06:16 ______ 21.00º ______ 0.00V ______ 1281.25rpm ______ 0 ______ 3.33ms ______ 4
2000-01-02 08:06:16 ______ 23.00º ______ 0.02V ______ 1343.75rpm ______ 0 ______ 3.33ms ______ 4
2000-01-02 08:06:17 ______ 23.00º ______ 0.02V ______ 1343.75rpm ______ 0 ______ 3.33ms ______ 4
2000-01-02 08:06:17 ______ 23.00º ______ 0.04V ______ 1343.75rpm ______ 0 ______ 3.58ms ______ 5
2000-01-02 08:06:17 ______ 24.00º ______ 0.04V ______ 1375.00rpm ______ 0 ______ 3.58ms ______ 5
2000-01-02 08:06:17 ______ 23.00º ______ 0.16V ______ 1406.25rpm ______ 0 ______ 3.58ms ______ 5
2000-01-02 08:06:17 ______ 24.00º ______ 0.74V ______ 1437.50rpm ______ 1 ______ 3.58ms ______ 5
2000-01-02 08:06:17 ______ 24.00º ______ 0.82V ______ 1437.50rpm ______ 1 ______ 3.58ms ______ 5
2000-01-02 08:06:17 ______ 24.00º ______ 0.84V ______ 1437.50rpm ______ 1 ______ 3.58ms ______ 5
2000-01-02 08:06:17 ______ 25.00º ______ 0.84V ______ 1437.50rpm ______ 0 ______ 3.58ms ______ 5
2000-01-02 08:06:17 ______ 24.00º ______ 0.84V ______ 1406.25rpm ______ 0 ______ 3.58ms ______ 5
2000-01-02 08:06:17 ______ 24.00º ______ 0.84V ______ 1437.50rpm ______ 0 ______ 3.58ms ______ 5
2000-01-02 08:06:17 ______ 26.00º ______ 0.82V ______ 1531.25rpm ______ 0 ______ 3.33ms ______ 5
2000-01-02 08:06:18 ______ 27.00º ______ 0.82V ______ 1625.00rpm ______ 1 ______ 3.33ms ______ 5
2000-01-02 08:06:18 ______ 28.00º ______ 0.82V ______ 1656.25rpm ______ 0 ______ 3.33ms ______ 5
2000-01-02 08:06:18 ______ 28.00º ______ 0.78V ______ 1718.75rpm ______ 0 ______ 3.07ms ______ 5
2000-01-02 08:06:18 ______ 29.00º ______ 0.74V ______ 1812.50rpm ______ 0 ______ 3.07ms ______ 5
2000-01-02 08:06:18 ______ 31.00º ______ 0.66V ______ 1875.00rpm ______ 0 ______ 3.07ms ______ 6
2000-01-02 08:06:18 ______ 32.00º ______ 0.27V ______ 1937.50rpm ______ 0 ______ 3.07ms ______ 6
2000-01-02 08:06:18 ______ 32.00º ______ 0.18V ______ 2000.00rpm ______ 0 ______ 3.07ms ______ 6
2000-01-02 08:06:18 ______ 33.00º ______ 0.76V ______ 2062.50rpm ______ 0 ______ 3.07ms ______ 6
2000-01-02 08:06:18 ______ 33.00º ______ 0.82V ______ 2093.75rpm ______ 0 ______ 3.07ms ______ 6
2000-01-02 08:06:18 ______ 33.00º ______ 0.84V ______ 2156.25rpm ______ 0 ______ 2.82ms ______ 6
2000-01-02 08:06:19 ______ 33.00º ______ 0.84V ______ 2250.00rpm ______ 0 ______ 2.82ms ______ 6
2000-01-02 08:06:19 ______ 34.00º ______ 0.84V ______ 2281.25rpm ______ 0 ______ 2.82ms ______ 6
2000-01-02 08:06:19 ______ 34.00º ______ 0.84V ______ 2312.50rpm ______ 0 ______ 2.82ms ______ 6
2000-01-02 08:06:19 ______ 34.00º ______ 0.84V ______ 2406.25rpm ______ 0 ______ 2.82ms ______ 7
2000-01-02 08:06:19 ______ 34.00º ______ 0.84V ______ 2437.50rpm ______ 0 ______ 2.82ms ______ 7
2000-01-02 08:06:19 ______ 34.00º ______ 0.84V ______ 2500.00rpm ______ 0 ______ 2.82ms ______ 7
2000-01-02 08:06:19 ______ 34.00º ______ 0.82V ______ 2562.50rpm ______ 0 ______ 2.82ms ______ 7
2000-01-02 08:06:19 ______ 34.00º ______ 0.80V ______ 2625.00rpm ______ 0 ______ 2.82ms ______ 7
2000-01-02 08:06:19 ______ 34.00º ______ 0.78V ______ 2687.50rpm ______ 0 ______ 3.07ms ______ 8
2000-01-02 08:06:19 ______ 33.00º ______ 0.74V ______ 2750.00rpm ______ 0 ______ 3.07ms ______ 9
2000-01-02 08:06:20 ______ 34.00º ______ 0.20V ______ 2843.75rpm ______ 0 ______ 3.07ms ______ 9
2000-01-02 08:06:20 ______ 34.00º ______ 0.06V ______ 2906.25rpm ______ 0 ______ 3.07ms ______ 9
2000-01-02 08:06:20 ______ 34.00º ______ 0.72V ______ 2968.75rpm ______ 0 ______ 3.07ms ______ 9
2000-01-02 08:06:20 ______ 34.00º ______ 0.80V ______ 3031.25rpm ______ 0 ______ 3.07ms ______ 9
2000-01-02 08:06:20 ______ 34.00º ______ 0.80V ______ 3125.00rpm ______ 0 ______ 3.07ms ______ 10
2000-01-02 08:06:20 ______ 34.00º ______ 0.80V ______ 3187.50rpm ______ 0 ______ 3.07ms ______ 10
2000-01-02 08:06:20 ______ 33.00º ______ 0.18V ______ 3218.75rpm ______ 0 ______ 3.33ms ______ 11
2000-01-02 08:06:20 ______ 34.00º ______ 0.02V ______ 3312.50rpm ______ 0 ______ 3.84ms ______ 13
2000-01-02 08:06:20 ______ 33.00º ______ 0.04V ______ 3406.25rpm ______ 0 ______ 4.10ms ______ 14
2000-01-02 08:06:21 ______ 33.00º ______ 0.76V ______ 3593.75rpm ______ 0 ______ 4.10ms ______ 15
2000-01-02 08:06:21 ______ 32.00º ______ 0.82V ______ 3625.00rpm ______ 0 ______ 4.10ms ______ 15
2000-01-02 08:06:21 ______ 32.00º ______ 0.84V ______ 3843.75rpm ______ 0 ______ 5.12ms ______ 21
2000-01-02 08:06:21 ______ 32.00º ______ 0.86V ______ 3968.75rpm ______ 0 ______ 5.89ms ______ 24
2000-01-02 08:06:21 ______ 31.00º ______ 0.88V ______ 4093.75rpm ______ 0 ______ 7.42ms ______ 32
2000-01-02 08:06:21 ______ 29.00º ______ 0.90V ______ 4343.75rpm ______ 0 ______ 8.96ms ______ 41
2000-01-02 08:06:21 ______ 28.00º ______ 0.90V ______ 4500.00rpm ______ 0 ______ 11.78ms ______ 56
2000-01-02 08:06:21 ______ 24.00º ______ 0.90V ______ 4718.75rpm ______ 1 ______ 15.87ms ______ 80
2000-01-02 08:06:22 ______ 20.00º ______ 0.86V ______ 4562.50rpm ______ 1 ______ 16.90ms ______ 82
2000-01-02 08:06:22 ______ 17.00º ______ 0.84V ______ 5000.00rpm ______ 1 ______ 17.15ms ______ 91
2000-01-02 08:06:22 ______ 20.00º ______ 0.86V ______ 5375.00rpm ______ 1 ______ 9.98ms ______ 57
2000-01-02 08:06:22 ______ 24.00º ______ 0.78V ______ 4906.25rpm ______ 0 ______ 3.07ms ______ 16
2000-01-02 08:06:22 ______ 39.00º ______ 0.86V ______ 4843.75rpm ______ 0 ______ 1.79ms ______ 9
2000-01-02 08:06:22 ______ 45.00º ______ 0.84V ______ 4656.25rpm ______ 0 ______ 1.54ms ______ 7
2000-01-02 08:06:22 ______ 44.00º ______ 0.74V ______ 4375.00rpm ______ 0 ______ 1.79ms ______ 8
2000-01-02 08:06:22 ______ 43.00º ______ 0.66V ______ 4062.50rpm ______ 0 ______ 1.28ms ______ 5
2000-01-02 08:06:23 ______ 41.00º ______ 0.66V ______ 3968.75rpm ______ 0 ______ 1.28ms ______ 5
2000-01-02 08:06:23 ______ 41.00º ______ 0.64V ______ 3687.50rpm ______ 0 ______ 1.28ms ______ 5
2000-01-02 08:06:23 ______ 40.00º ______ 0.78V ______ 3500.00rpm ______ 0 ______ 1.54ms ______ 5
2000-01-02 08:06:23 ______ 40.00º ______ 0.84V ______ 3281.25rpm ______ 0 ______ 2.05ms ______ 7
2000-01-02 08:06:23 ______ 38.00º ______ 0.04V ______ 3000.00rpm ______ 0 ______ 2.30ms ______ 7
2000-01-02 08:06:23 ______ 36.00º ______ 0.02V ______ 2875.00rpm ______ 0 ______ 3.07ms ______ 9
2000-01-02 08:06:23 ______ 34.00º ______ 0.02V ______ 3000.00rpm ______ 0 ______ 3.58ms ______ 11
2000-01-02 08:06:23 ______ 33.00º ______ 0.06V ______ 2937.50rpm ______ 0 ______ 3.84ms ______ 12
2000-01-02 08:06:23 ______ 33.00º ______ 0.80V ______ 3000.00rpm ______ 0 ______ 4.10ms ______ 13
2000-01-02 08:06:24 ______ 33.00º ______ 0.86V ______ 3031.25rpm ______ 0 ______ 3.84ms ______ 12
2000-01-02 08:06:24 ______ 33.00º ______ 0.86V ______ 3062.50rpm ______ 0 ______ 4.10ms ______ 13
2000-01-02 08:06:24 ______ 32.00º ______ 0.84V ______ 3093.75rpm ______ 0 ______ 4.35ms ______ 14
2000-01-02 08:06:24 ______ 32.00º ______ 0.84V ______ 3187.50rpm ______ 0 ______ 4.35ms ______ 14
2000-01-02 08:06:24 ______ 32.00º ______ 0.86V ______ 3187.50rpm ______ 0 ______ 4.61ms ______ 15
2000-01-02 08:06:24 ______ 31.00º ______ 0.84V ______ 3250.00rpm ______ 0 ______ 5.12ms ______ 17
2000-01-02 08:06:24 ______ 30.00º ______ 0.80V ______ 3281.25rpm ______ 0 ______ 5.12ms ______ 17
2000-01-02 08:06:24 ______ 29.00º ______ 0.80V ______ 3312.50rpm ______ 0 ______ 5.38ms ______ 19
2000-01-02 08:06:24 ______ 28.00º ______ 0.80V ______ 3437.50rpm ______ 0 ______ 5.63ms ______ 20
2000-01-02 08:06:25 ______ 26.00º ______ 0.72V ______ 3531.25rpm ______ 0 ______ 8.96ms ______ 33
2000-01-02 08:06:25 ______ 25.00º ______ 0.82V ______ 3500.00rpm ______ 0 ______ 9.73ms ______ 36
2000-01-02 08:06:25 ______ 24.00º ______ 0.90V ______ 3750.00rpm ______ 0 ______ 11.01ms ______ 44
2000-01-02 08:06:25 ______ 23.00º ______ 0.90V ______ 3750.00rpm ______ 0 ______ 12.54ms ______ 50
2000-01-02 08:06:25 ______ 21.00º ______ 0.90V ______ 3812.50rpm ______ 0 ______ 14.08ms ______ 57
2000-01-02 08:06:25 ______ 20.00º ______ 0.90V ______ 3906.25rpm ______ 0 ______ 16.13ms ______ 67
2000-01-02 08:06:25 ______ 18.00º ______ 0.90V ______ 4093.75rpm ______ 0 ______ 18.18ms ______ 79
2000-01-02 08:06:25 ______ 18.00º ______ 0.88V ______ 4156.25rpm ______ 0 ______ 18.43ms ______ 81
2000-01-02 08:06:26 ______ 19.00º ______ 0.88V ______ 4437.50rpm ______ 0 ______ 18.18ms ______ 86
2000-01-02 08:06:26 ______ 19.00º ______ 0.86V ______ 4468.75rpm ______ 1 ______ 18.43ms ______ 88
2000-01-02 08:06:26 ______ 18.00º ______ 0.86V ______ 4718.75rpm ______ 1 ______ 17.66ms ______ 89
2000-01-02 08:06:26 ______ 18.00º ______ 0.86V ______ 4906.25rpm ______ 1 ______ 17.41ms ______ 91
2000-01-02 08:06:26 ______ 17.00º ______ 0.86V ______ 5062.50rpm ______ 1 ______ 17.41ms ______ 94
2000-01-02 08:06:26 ______ 18.00º ______ 0.86V ______ 5187.50rpm ______ 0 ______ 17.15ms ______ 95
2000-01-02 08:06:26 ______ 20.00º ______ 0.86V ______ 5343.75rpm ______ 0 ______ 17.15ms ______ 97
2000-01-02 08:06:27 ______ 20.00º ______ 0.86V ______ 5468.75rpm ______ 0 ______ 16.64ms ______ 97
2000-01-02 08:06:27 ______ 21.00º ______ 0.86V ______ 5593.75rpm ______ ______ 10.75ms ______ 64
2000-01-02 08:06:27 ______ 23.00º ______ 0.86V ______ 6156.25rpm ______ 0 ______ 11.52ms ______ 75
2000-01-02 08:06:27 ______ 24.00º ______ 0.86V ______ 6250.00rpm ______ 0 ______ 14.85ms ______ 99
2000-01-02 08:06:28 ______ 22.00º ______ 0.86V ______ 6437.50rpm ______ 0 ______ 14.85ms ______ 102
2000-01-02 08:06:28 ______ 24.00º ______ 0.86V ______ 6531.25rpm ______ 0 ______ 14.59ms ______ 101
2000-01-02 08:06:28 ______ 22.00º ______ 0.86V ______ 6500.00rpm ______ 0 ______ 14.08ms ______ 97
2000-01-02 08:06:28 ______ 22.00º ______ 0.86V ______ 6625.00rpm ______ 1 ______ 14.08ms ______ 99
2000-01-02 08:06:28 ______ 21.00º ______ 0.86V ______ 6500.00rpm ______ 1 ______ 13.82ms ______ 96
2000-01-02 08:06:28 ______ 21.00º ______ 0.86V ______ 6781.25rpm ______ 1 ______ 13.82ms ______ 100
2000-01-02 08:06:28 ______ 23.00º ______ 0.86V ______ 6781.25rpm ______ 0 ______ 13.31ms ______ 96
2000-01-02 08:06:28 ______ 22.00º ______ 0.86V ______ 7000.00rpm ______ 0 ______ 2.05ms ______ 15
2000-01-02 08:06:28 ______ 33.00º ______ 0.74V ______ 6781.25rpm ______ 0 ______ 1.54ms ______ 11
2000-01-02 08:06:28 ______ 45.00º ______ 0.86V ______ 6343.75rpm ______ 0 ______ 1.79ms ______ 12
2000-01-02 08:06:29 ______ 45.00º ______ 0.70V ______ 6093.75rpm ______ 0 ______ 1.54ms ______ 10
2000-01-02 08:06:29 ______ 45.00º ______ 0.64V ______ 5625.00rpm ______ 0 ______ 1.28ms ______ 7
2000-01-02 08:06:29 ______ 45.00º ______ 0.62V ______ 5406.25rpm ______ 0 ______ 1.28ms ______ 7
2000-01-02 08:06:29 ______ 45.00º ______ 0.66V ______ 5093.75rpm ______ 0 ______ 1.28ms ______ 6
2000-01-02 08:06:29 ______ 45.00º ______ 0.80V ______ 4906.25rpm ______ 0 ______ 1.28ms ______ 6
2000-01-02 08:06:29 ______ 45.00º ______ 0.82V ______ 4656.25rpm ______ 0 ______ 0.00ms ______ 0
2000-01-02 08:06:29 ______ 31.00º ______ 0.82V ______ 4562.50rpm ______ 0 ______ 0.00ms ______ 0
2000-01-02 08:06:29 ______ 30.00º ______ 0.41V ______ 4250.00rpm ______ 0 ______ 0.00ms ______ 0
2000-01-02 08:06:29 ______ 29.00º ______ 0.00V ______ 3968.75rpm ______ 0 ______ 0.00ms ______ 0
2000-01-02 08:06:30 ______ 28.00º ______ 0.00V ______ 3750.00rpm ______ 0 ______ 0.00ms ______ 0
2000-01-02 08:06:30 ______ 27.00º ______ 0.00V ______ 3625.00rpm ______ 0 ______ 0.00ms ______ 0
2000-01-02 08:06:30 ______ 27.00º ______ 0.00V ______ 3375.00rpm ______ 0 ______ 0.00ms ______ 0
2000-01-02 08:06:30 ______ 27.00º ______ 0.00V ______ 3218.75rpm ______ 0 ______ 0.00ms ______ 0
2000-01-02 08:06:30 ______ 26.00º ______ 0.00V ______ 3031.25rpm ______ 0 ______ 0.00ms ______ 0
2000-01-02 08:06:30 ______ 26.00º ______ 0.00V ______ 2906.25rpm ______ 0 ______ 0.00ms ______ 0
2000-01-02 08:06:30 ______ 26.00º ______ 0.00V ______ 2687.50rpm ______ 0 ______ 0.00ms ______ 0
2000-01-02 08:06:30 ______ 25.00º ______ 0.00V ______ 2531.25rpm ______ 0 ______ 0.00ms ______ 0
2000-01-02 08:06:30 ______ 25.00º ______ 0.00V ______ 2375.00rpm ______ 0 ______ 0.00ms ______ 0
2000-01-02 08:06:31 ______ 25.00º ______ 0.00V ______ 2218.75rpm ______ 0 ______ 0.00ms ______ 0
______ ______ ______ ______ ______ ______
2000-01-02 08:07:33 ______ 9.00º ______ 0.74V ______ 937.50rpm ______ 0 ______ 1.79ms ______ 1
2000-01-02 08:07:33 ______ 9.00º ______ 0.70V ______ 937.50rpm ______ 0 ______ 1.79ms ______ 1
2000-01-02 08:07:33 ______ 9.00º ______ 0.14V ______ 968.75rpm ______ 0 ______ 1.79ms ______ 1
2000-01-02 08:07:33 ______ 10.00º ______ 0.04V ______ 1000.00rpm ______ 0 ______ 1.79ms ______ 1
2000-01-02 08:07:33 ______ 13.00º ______ 0.04V ______ 1000.00rpm ______ 0 ______ 1.79ms ______ 1
2000-01-02 08:07:34 ______ 13.00º ______ 0.04V ______ 1031.25rpm ______ 0 ______ 1.79ms ______ 1
2000-01-02 08:07:34 ______ 14.00º ______ 0.04V ______ 1031.25rpm ______ 0 ______ 2.30ms ______ 2
2000-01-02 08:07:34 ______ 15.00º ______ 0.02V ______ 1062.50rpm ______ 0 ______ 2.82ms ______ 3
2000-01-02 08:07:34 ______ 14.00º ______ 0.02V ______ 1000.00rpm ______ 0 ______ 3.07ms ______ 3
2000-01-02 08:07:34 ______ 14.00º ______ 0.00V ______ 1031.25rpm ______ 0 ______ 3.33ms ______ 3
2000-01-02 08:07:34 ______ 16.00º ______ 0.00V ______ 1156.25rpm ______ 0 ______ 3.58ms ______ 4
2000-01-02 08:07:34 ______ 21.00º ______ 0.00V ______ 1250.00rpm ______ 0 ______ 3.58ms ______ 4
2000-01-02 08:07:34 ______ 22.00º ______ 0.00V ______ 1343.75rpm ______ 0 ______ 3.58ms ______ 5
2000-01-02 08:07:34 ______ 23.00º ______ 0.02V ______ 1406.25rpm ______ 0 ______ 3.58ms ______ 5
2000-01-02 08:07:34 ______ 25.00º ______ 0.04V ______ 1468.75rpm ______ 0 ______ 3.58ms ______ 5
2000-01-02 08:07:34 ______ 25.00º ______ 0.45V ______ 1500.00rpm ______ 0 ______ 3.58ms ______ 5
2000-01-02 08:07:35 ______ 25.00º ______ 0.78V ______ 1562.50rpm ______ 0 ______ 3.58ms ______ 5
2000-01-02 08:07:35 ______ 26.00º ______ 0.80V ______ 1625.00rpm ______ 0 ______ 3.58ms ______ 6
2000-01-02 08:07:35 ______ 27.00º ______ 0.80V ______ 1656.25rpm ______ 0 ______ 3.58ms ______ 6
2000-01-02 08:07:35 ______ 27.00º ______ 0.78V ______ 1687.50rpm ______ 0 ______ 3.58ms ______ 6
2000-01-02 08:07:35 ______ 28.00º ______ 0.72V ______ 1718.75rpm ______ 0 ______ 3.58ms ______ 6
2000-01-02 08:07:35 ______ 27.00º ______ 0.29V ______ 1750.00rpm ______ 2 ______ 3.58ms ______ 6
2000-01-02 08:07:35 ______ 27.00º ______ 0.06V ______ 1781.25rpm ______ 1 ______ 3.58ms ______ 6
2000-01-02 08:07:35 ______ 28.00º ______ 0.08V ______ 1843.75rpm ______ 1 ______ 3.58ms ______ 7
2000-01-02 08:07:35 ______ 29.00º ______ 0.70V ______ 1875.00rpm ______ 1 ______ 3.58ms ______ 7
2000-01-02 08:07:35 ______ 30.00º ______ 0.82V ______ 1906.25rpm ______ 1 ______ 3.33ms ______ 6
2000-01-02 08:07:36 ______ 30.00º ______ 0.82V ______ 1906.25rpm ______ 0 ______ 3.07ms ______ 6
2000-01-02 08:07:36 ______ 32.00º ______ 0.86V ______ 1875.00rpm ______ 0 ______ 2.82ms ______ 5
2000-01-02 08:07:36 ______ 32.00º ______ 0.86V ______ 1968.75rpm ______ 0 ______ 2.82ms ______ 5
2000-01-02 08:07:36 ______ 34.00º ______ 0.86V ______ 2062.50rpm ______ 0 ______ 2.56ms ______ 5
2000-01-02 08:07:36 ______ 34.00º ______ 0.86V ______ 2031.25rpm ______ 0 ______ 2.56ms ______ 5
2000-01-02 08:07:36 ______ 34.00º ______ 0.84V ______ 2187.50rpm ______ 0 ______ 2.56ms ______ 5
2000-01-02 08:07:36 ______ 34.00º ______ 0.82V ______ 2250.00rpm ______ 0 ______ 2.56ms ______ 6
2000-01-02 08:07:36 ______ 34.00º ______ 0.80V ______ 2156.25rpm ______ 0 ______ 2.56ms ______ 5
2000-01-02 08:07:36 ______ 34.00º ______ 0.80V ______ 2250.00rpm ______ 0 ______ 2.82ms ______ 6
2000-01-02 08:07:37 ______ 34.00º ______ 0.74V ______ 2406.25rpm ______ 0 ______ 2.82ms ______ 7
2000-01-02 08:07:37 ______ 34.00º ______ 0.06V ______ 2406.25rpm ______ 0 ______ 3.07ms ______ 7
2000-01-02 08:07:37 ______ 34.00º ______ 0.04V ______ 2437.50rpm ______ 0 ______ 3.33ms ______ 8
2000-01-02 08:07:37 ______ 33.00º ______ 0.06V ______ 2562.50rpm ______ 0 ______ 3.58ms ______ 9
2000-01-02 08:07:37 ______ 33.00º ______ 0.25V ______ 2656.25rpm ______ 0 ______ 3.58ms ______ 10
2000-01-02 08:07:37 ______ 32.00º ______ 0.80V ______ 2687.50rpm ______ 0 ______ 3.58ms ______ 10
2000-01-02 08:07:37 ______ 33.00º ______ 0.82V ______ 2843.75rpm ______ 0 ______ 3.58ms ______ 10
2000-01-02 08:07:37 ______ 33.00º ______ 0.84V ______ 2937.50rpm ______ 0 ______ 3.58ms ______ 11
2000-01-02 08:07:37 ______ 33.00º ______ 0.84V ______ 3000.00rpm ______ 0 ______ 3.84ms ______ 12
2000-01-02 08:07:37 ______ 33.00º ______ 0.80V ______ 3125.00rpm ______ 0 ______ 4.10ms ______ 13
2000-01-02 08:07:38 ______ 32.00º ______ 0.80V ______ 3250.00rpm ______ 0 ______ 4.35ms ______ 15
2000-01-02 08:07:38 ______ 32.00º ______ 0.82V ______ 3375.00rpm ______ 0 ______ 4.35ms ______ 15
2000-01-02 08:07:38 ______ 31.00º ______ 0.80V ______ 3593.75rpm ______ 0 ______ 4.61ms ______ 17
2000-01-02 08:07:38 ______ 30.00º ______ 0.80V ______ 3656.25rpm ______ 0 ______ 6.40ms ______ 25
2000-01-02 08:07:38 ______ 30.00º ______ 0.86V ______ 3906.25rpm ______ 0 ______ 7.68ms ______ 32
2000-01-02 08:07:38 ______ 28.00º ______ 0.90V ______ 4125.00rpm ______ 0 ______ 9.22ms ______ 40
2000-01-02 08:07:38 ______ 26.00º ______ 0.90V ______ 4281.25rpm ______ 0 ______ 11.26ms ______ 51
2000-01-02 08:07:38 ______ 24.00º ______ 0.90V ______ 4500.00rpm ______ 0 ______ 13.57ms ______ 65
2000-01-02 08:07:39 ______ 21.00º ______ 0.90V ______ 4625.00rpm ______ 0 ______ 16.38ms ______ 80
2000-01-02 08:07:39 ______ 19.00º ______ 0.88V ______ 4875.00rpm ______ 0 ______ 17.15ms ______ 89
2000-01-02 08:07:39 ______ 18.00º ______ 0.86V ______ 5187.50rpm ______ 0 ______ 16.38ms ______ 90
2000-01-02 08:07:39 ______ 19.00º ______ 0.86V ______ ______ 0 ______ 1.28ms ______
2000-01-02 08:07:40 ______ 44.00º ______ 0.68V ______ 4437.50rpm ______ 0 ______ 1.54ms ______ 7
2000-01-02 08:07:40 ______ 30.00º ______ 0.66V ______ 4187.50rpm ______ 0 ______ 0.00ms ______ 0
2000-01-02 08:07:40 ______ 29.00º ______ 0.84V ______ 4031.25rpm ______ 0 ______ 0.00ms ______ 0
2000-01-02 08:07:40 ______ 28.00º ______ 0.66V ______ 3750.00rpm ______ 0 ______ 1.28ms ______ 5
2000-01-02 08:07:40 ______ 38.00º ______ 0.00V ______ 3656.25rpm ______ 0 ______ 1.28ms ______ 5
2000-01-02 08:07:40 ______ 40.00º ______ 0.06V ______ 3500.00rpm ______ 0 ______ 1.54ms ______ 5
2000-01-02 08:07:40 ______ 40.00º ______ 0.80V ______ 3375.00rpm ______ 0 ______ 2.05ms ______ 7
2000-01-02 08:07:40 ______ 39.00º ______ 0.47V ______ 3187.50rpm ______ 0 ______ 2.30ms ______ 7
2000-01-02 08:07:40 ______ 36.00º ______ 0.86V ______ 3000.00rpm ______ 0 ______ 2.82ms ______ 9
2000-01-02 08:07:41 ______ 34.00º ______ 0.80V ______ 2937.50rpm ______ 0 ______ 3.33ms ______ 10
2000-01-02 08:07:41 ______ 34.00º ______ 0.76V ______ 3031.25rpm ______ 0 ______ 3.58ms ______ 11
2000-01-02 08:07:41 ______ 33.00º ______ 0.84V ______ 3000.00rpm ______ 0 ______ 3.58ms ______ 11
2000-01-02 08:07:41 ______ 33.00º ______ 0.84V ______ 3062.50rpm ______ 0 ______ 3.84ms ______ 12
2000-01-02 08:07:41 ______ 33.00º ______ 0.84V ______ 3093.75rpm ______ 0 ______ 4.10ms ______ 13
2000-01-02 08:07:41 ______ 32.00º ______ 0.84V ______ 3156.25rpm ______ 0 ______ 4.10ms ______ 13
2000-01-02 08:07:41 ______ 32.00º ______ 0.84V ______ 3281.25rpm ______ 0 ______ 4.10ms ______ 14
2000-01-02 08:07:42 ______ 32.00º ______ 0.82V ______ 3281.25rpm ______ 0 ______ 4.10ms ______ 14
2000-01-02 08:07:42 ______ 32.00º ______ 0.80V ______ 3281.25rpm ______ 0 ______ 4.10ms ______ 14
2000-01-02 08:07:42 ______ 32.00º ______ 0.74V ______ 3343.75rpm ______ 0 ______ 4.61ms ______ 16
2000-01-02 08:07:42 ______ 30.00º ______ 0.06V ______ 3375.00rpm ______ 0 ______ 5.12ms ______ 18
2000-01-02 08:07:42 ______ 29.00º ______ 0.08V ______ 3531.25rpm ______ 0 ______ 7.42ms ______ 28
2000-01-02 08:07:42 ______ 27.00º ______ 0.76V ______ 3593.75rpm ______ 0 ______ 8.45ms ______ 32
2000-01-02 08:07:42 ______ 26.00º ______ 0.90V ______ 3656.25rpm ______ 0 ______ 9.22ms ______ 36
2000-01-02 08:07:42 ______ 26.00º ______ 0.90V ______ 3781.25rpm ______ 0 ______ 10.75ms ______ 43
2000-01-02 08:07:43 ______ 24.00º ______ 0.90V ______ 3906.25rpm ______ 0 ______ 12.29ms ______ 51
2000-01-02 08:07:43 ______ 21.00º ______ 0.90V ______ 3937.50rpm ______ 1 ______ 14.34ms ______ 60
2000-01-02 08:07:43 ______ 20.00º ______ 0.90V ______ 4062.50rpm ______ 1 ______ 16.38ms ______ 71
2000-01-02 08:07:43 ______ 17.00º ______ 0.90V ______ 4125.00rpm ______ 1 ______ 17.41ms ______ 76
2000-01-02 08:07:43 ______ 17.00º ______ 0.88V ______ 4312.50rpm ______ 5 ______ 17.66ms ______ 81
2000-01-02 08:07:43 ______ 17.00º ______ 0.88V ______ 4531.25rpm ______ 8 ______ 17.66ms ______ 85
2000-01-02 08:07:43 ______ 16.00º ______ 0.88V ______ 4625.00rpm ______ 8 ______ 17.15ms ______ 84
2000-01-02 08:07:43 ______ 16.00º ______ 0.88V ______ 4781.25rpm ______ 8 ______ 17.41ms ______ 88
2000-01-02 08:07:44 ______ 15.00º ______ 0.86V ______ 4875.00rpm ______ 8 ______ 17.15ms ______ 89
2000-01-02 08:07:44 ______ 15.00º ______ 0.86V ______ 5093.75rpm ______ 255 ______ 8.70ms ______ 47
2000-01-02 08:07:44 ______ ______ 0.84V ______ 5750.00rpm ______ 6 ______ 15.10ms ______ 92
2000-01-02 08:07:44 ______ 22.00º ______ 0.84V ______ 6000.00rpm ______ 6 ______ 14.59ms ______ 93
2000-01-02 08:07:45 ______ 23.00º ______ 0.86V ______ 6062.50rpm ______ 6 ______ 13.82ms ______ 89
2000-01-02 08:07:45 ______ 23.00º ______ 0.86V ______ 6218.75rpm ______ 6 ______ 14.59ms ______ 96
2000-01-02 08:07:45 ______ 22.00º ______ 0.84V ______ 6093.75rpm ______ 6 ______ 14.59ms ______ 95
2000-01-02 08:07:45 ______ 21.00º ______ 0.86V ______ 6406.25rpm ______ 6 ______ 11.78ms ______ 80
2000-01-02 08:07:45 ______ 22.00º ______ 0.86V ______ 6343.75rpm ______ 5 ______ 15.10ms ______ 102
2000-01-02 08:07:45 ______ 21.00º ______ 0.86V ______ 6468.75rpm ______ 5 ______ 14.08ms ______ 97
2000-01-02 08:07:45 ______ 21.00º ______ 0.86V ______ 6625.00rpm ______ 7 ______ 13.31ms ______ 94
2000-01-02 08:07:45 ______ 23.00º ______ 0.86V ______ 6750.00rpm ______ 7 ______ 12.54ms ______ 90
2000-01-02 08:07:45 ______ 21.00º ______ 0.86V ______ 6843.75rpm ______ 7 ______ 13.31ms ______ 97
2000-01-02 08:07:46 ______ 17.00º ______ 0.84V ______ 6906.25rpm ______ 6 ______ 1.28ms ______ 9
2000-01-02 08:07:46 ______ 41.00º ______ 0.76V ______ 6500.00rpm ______ 0 ______ 1.79ms ______ 12
2000-01-02 08:07:46 ______ 45.00º ______ 0.78V ______ 6218.75rpm ______ 0 ______ 1.54ms ______ 10
2000-01-02 08:07:46 ______ 45.00º ______ 0.68V ______ 5843.75rpm ______ 0 ______ 1.28ms ______ 7
2000-01-02 08:07:46 ______ 45.00º ______ 0.70V ______ 5531.25rpm ______ 0 ______ 5.12ms ______ 30
2000-01-02 08:07:46 ______ 35.00º ______ 0.23V ______ 5250.00rpm ______ 0 ______ 8.45ms ______ 47
2000-01-02 08:07:46 ______ 29.00º ______ 0.88V ______ 4656.25rpm ______ 0 ______ 10.24ms ______ 50
2000-01-02 08:07:46 ______ 27.00º ______ 0.90V ______ 4625.00rpm ______ 1 ______ 11.26ms ______ 55
2000-01-02 08:07:47 ______ 23.00º ______ 0.90V ______ 4500.00rpm ______ 1 ______ 13.06ms ______ 62
2000-01-02 08:07:47 ______ 21.00º ______ 0.90V ______ 4500.00rpm ______ 0 ______ 15.10ms ______ 72
2000-01-02 08:07:47 ______ 20.00º ______ 0.90V ______ 4625.00rpm ______ 0 ______ 4.61ms ______ 22
2000-01-02 08:07:47 ______ 28.00º ______ 0.76V ______ 4218.75rpm ______ 0 ______ 2.30ms ______ 10
2000-01-02 08:07:47 ______ 35.00º ______ 0.68V ______ 4031.25rpm ______ 0 ______ 2.05ms ______ 8
2000-01-02 08:07:47 ______ 40.00º ______ 0.64V ______ 3875.00rpm ______ 0 ______ 1.54ms ______ 6
2000-01-02 08:07:47 ______ 41.00º ______ 0.64V ______ 3656.25rpm ______ 0 ______ 1.54ms ______ 6
2000-01-02 08:07:47 ______ 40.00º ______ 0.66V ______ 3468.75rpm ______ 0 ______ 1.54ms ______ 5
2000-01-02 08:07:48 ______ 40.00º ______ 0.64V ______ 3281.25rpm ______ 0 ______ 1.28ms ______ 4
2000-01-02 08:07:48 ______ 39.00º ______ 0.76V ______ 3125.00rpm ______ 0 ______ 1.28ms ______ 4
2000-01-02 08:07:48 ______ 39.00º ______ 0.88V ______ 3000.00rpm ______ 0 ______ 0.00ms ______ 0
2000-01-02 08:07:48 ______ 26.00º ______ 0.88V ______ 2875.00rpm ______ 0 ______ 0.00ms ______ 0
2000-01-02 08:07:48 ______ 26.00º ______ 0.88V ______ 2718.75rpm ______ 0 ______ 0.00ms ______ 0
2000-01-02 08:07:48 ______ 25.00º ______ 0.43V ______ 2593.75rpm ______ 0 ______ 0.00ms ______ 0
2000-01-02 08:07:48 ______ 25.00º ______ 0.00V ______ 2468.75rpm ______ 0 ______ 0.00ms ______ 0
2000-01-02 08:07:48 ______ 25.00º ______ 0.00V ______ 2312.50rpm ______ 0 ______ 0.00ms ______ 0
2000-01-02 08:07:48 ______ 25.00º ______ 0.00V ______ 2187.50rpm ______ 0 ______ 0.00ms ______ 0
2000-01-02 08:07:48 ______ 24.00º ______ 0.00V ______ 2031.25rpm ______ 0 ______ 0.00ms ______ 0
2000-01-02 08:07:48 ______ 24.00º ______ 0.00V ______ 1906.25rpm ______ 0 ______ 0.00ms ______ 0
2000-01-02 08:07:49 ______ 26.00º ______ 0.00V ______ 1781.25rpm ______ 0 ______ 0.00ms ______ 0
2000-01-02 08:07:49 ______ 23.00º ______ 0.00V ______ 1656.25rpm ______ 0 ______ 0.00ms ______ 0
2000-01-02 08:07:49 ______ 20.00º ______ 0.00V ______ 1562.50rpm ______ 0 ______ 0.00ms ______ 0
2000-01-02 08:07:49 ______ 17.00º ______ 0.00V ______ 1437.50rpm ______ 0 ______ 0.00ms ______ 0
2000-01-02 08:07:49 ______ 14.00º ______ 0.00V ______ 1312.50rpm ______ 0 ______ 0.00ms ______ 0
2000-01-02 08:07:49 ______ 14.00º ______ 0.00V ______ 1187.50rpm ______ 0 ______ 1.54ms ______ 1
2000-01-02 08:07:49 ______ 14.00º ______ 0.00V ______ 1093.75rpm ______ 0 ______ 1.54ms ______ 1
2000-01-02 08:07:49 ______ 15.00º ______ 0.00V ______ 1000.00rpm ______ 0 ______ 1.79ms ______ 1
Those weren't gears. Those were the runs. I did a run then pulled over in the next neighborhood for about 5 minutes, then do another. Ever since I graduated early this passed december, I've had so much time to do stuff to the car because I don't start college until august and I don't start working full time until next week. hah, it took me long enough to start a full-time job. It took a while because I'm still a minor.
Recently, the 3" electric cutout suddenly stopped opening, so I put the old 2.25" manual cutout back in. Do you think there will be a big difference in my safc settings? The electric cutout was placed right after the stock downpipe, so putting the manual back in shouldn't change it much, right?
I am not sure you figured out your problems yet but i've been looking at your idc's compared to your ipw and they arern't right. Your idc's are reading alot higher than your ipw are telling me your idc's should be.
Whats your base fp and base timing? Your timing is pretty aggressive but thats due to your safc settings being so far in the negative. I was knocking with my 650's at 42psi bfp because my timing was too high with such negative safc settings. I lowered my base fp to 37psi and raised the boost 2 psi so i could add fuel with the safc and it lowered my timing to about 20* at wot and then i was finally able to tune for 0 knock and still keep timing around 20* which is still probly a bit too high but i'm just happy to have 0 knock on pump gas with a s16g at 18psi without a fmic. With more tuning i think 20psi on my setup with 0-3 knock is possible. Time and tuning will tell.
This is a great site to cross reference your ipw's into idc's http://www.ecanfix.com/~mdhamilton/dutycyclechart.html
Everything is different now. The INJD wasn't right [the ones I posted]. The duty cycles show differently on the logger than on the computer which leads me to believe there is something wrong with the program when uploading duty cycle information.
Since those posts, the talon had a full Apexi exhaust and a retune by me and my brother. Everything is good and the boost is set to stock and creeps to 15 on low boost. For the low boost, it is tuned pretty good for the street. No knock and pulls good.
High boost took a while to get tuned because on the first run(we didnt change the safc settings at the time), the boost hit 28 psi and fell to 23. Let me say, THAT WAS FREAKIN FAST!.. What was also cool was that there was NO KNOCK whatsoever and that timing was great and the Injectors didn't max out. Or course we wanted to be safe and have the turbo last long, so we turned it down and retuned the high boost from the beginning, starting with 18psi and we worked our way up to 24. Logs look good and the car felt great (of course not as great as 28psi).
We took it to the track and my brother was driving (it's his car) and the best he pulled off in his 3 attempts was 14.2.. He said his problem is his launches because he always slips too much or too fast and bogs, thus his 60' was 2.0.
Next time we're looking forward to low 13s or possibly 12s, but we'll see.
