garrett center section turbine housing fittment
2blue4uRS
Jun 10, 2004
Newark, Ohio
I'm trying to find/figure out a Mitsu style turbine housing that bolts up to a garrett center section. i have a T3/T4 57 trim with the ford 5 bolt housing and I want to replace it with a Mitsu style one that will work with the center section so I can just bolt it up and swap it out. Anyone know? Where I can find one?
Both precision turbo and bullseye make turbine housings that will meet your needs.
PTE uses a larger (.63A/R) cast iron housing and Bullseye Power has a casted Stainless Steel that is polished and looks awesome but is a .55A/R. That is not necessarily a bad thing. You will see a little more response and quicker spool but the PTE can make a hair more on the top side.
Can't really go wrong either way bud.
best of luck.
