eclipsh
- 1,608
- 65
- Jun 16, 2005
Durango,
Colorado
I was thinking I could take the 5v (?) signal going to the tachometer and use it as a reference for a potentiometer. If I understand the gizmos correctly, I could set it to allow current through once a certain voltage is reached and use that to flip the solenoid (or a relay which would flip the solenoid).
I might be dead wrong on the tool I need to do this so I thought I'd ask arround here. What tool do I need that will cause a switch to flip when a chosen voltage is reached? Of course, it has to work in a car to be of use.
Thanks for any ideas you can send my way.
Before any odd comments show up: I have all the necessary parts to run the intake, I am just looking into a tunable method of triggering it.
I'm not getting rid of it either, I prefer mid-range torque over high end.
